Home » Modeling » TMF (Xtext) » Custom scope provider
Custom scope provider [message #1859690] |
Thu, 22 June 2023 11:26  |
I'm trying to implement my custom scope provider for my own DSL.
Here is a part of it's definition:
VariableDeclarationNode:
{VariableDeclarationNode} name=NodeId '=' target=VariableDeclarationTarget
VariableDeclarationTarget:
ComponentNode;
RelationNode:
{RelationNode} (source=[VariableDeclarationNode])? '->' target=[VariableDeclarationNode] (description=STRING (technology=STRING (tags+=STRING*))?)?
The RelationNode holds two references so in the end I would be capable of doing something like this:
component1 = component "SomeComponent"
component2 = component "Another"
component1 -> component2
It works well for very simple cases like this but the feature I'm working right now is a possilibty to "include" elements from other resources like this:
!import "classpath:/component1.xxx"
where component1.xxx would contain:
I've prepared a resolver mechanism that is capable of reading model from given URI, then I traverse trough the elements of the loaded model and if I find the VariableDeclaration then I add it to the scope for Relation.target and Relation.source.
This works well in tests, but, when I start using generated LSP it all goes crazy - when I first time import the file and write the relation immedietaly then it kinda.... works, but any additional edit or restarting the IDE instance that uses this LSP ends up with LSP unable to find component1 declaration.
What I might be doing wrong? When I'm using the default scope provider everything works pretty well but the variables are available globally and even when i dont use !include keyword.
Please help :(
I can share some more code if necessary...
Re: Custom scope provider [message #1859693 is a reply to message #1859692] |
Thu, 22 June 2023 13:57   |
Basically I'm rewriting this DSL: https://structurizr.com/dsl or at least trying ;)
I have a custom component I call IncludeResolver, I used it in both validator and scope provider, so in short the method that loads the included model looks like following:
public Model resolveInclude(IncludeNode include,
CircularIncludeGuard circularIncludeGuard,
ResourceSet resourceSet) throws IncludeError {
if (circularIncludeGuard.alreadyIncluded(include)) {
throw new IncludeError("Circular includes are forbidden!");
String importURI = include.getImportURI();
URI uri = URI.createURI(importURI);
try {
Resource resource = resourceSet.getResource(uri, true);
circularIncludeGuard.register(include);
for (EObject importedObject : resource.getContents()) {
if (importedObject instanceof Model includedModel) {
return includedModel;
throw new IncludeError("Unable to find model in included resource.");
} catch (Throwable throwable) {
throw new IncludeError(throwable);
CircularIncludeGuard is just checking if there are circular includes going on...
I'm including whole resolver code here:
public class IncludeResolver {
public Model resolveModel(Model originalModel) throws IncludeError {
ResourceSet resourceSet = originalModel.eResource().getResourceSet();
Model clonedModel = EcoreUtil.copy(originalModel);
doLinkingInModel(clonedModel, new CircularIncludeGuard(), resourceSet);
return clonedModel;
try {
private void doLinkingInModel(Model model,
ArrayList<NodeType> nodeTypes = new ArrayList<>(model.getElements());
for (NodeType modelNode : nodeTypes) {
linkModelNode(model, modelNode, circularIncludeGuard, resourceSet);
private void linkModelNode(Model model,
EObject modelNode,
if (modelNode instanceof VariableDeclarationNode variableDeclaration) {
linkModelNode(model, variableDeclaration.getTarget(), circularIncludeGuard, resourceSet);
if (modelNode instanceof IncludeNode include) {
includeResource(new ModelIncludeTarget(model), include, circularIncludeGuard, resourceSet);
} else if (modelNode instanceof GroupNode group) {
doLinkingInGroup(group, circularIncludeGuard, resourceSet);
} else if (modelNode instanceof ContainerNode container) {
doLinkingInContainer(container, circularIncludeGuard, resourceSet);
} else if (modelNode instanceof SoftwareSystemNode softwareSystem) {
doLinkingInSoftwareSystem(softwareSystem, circularIncludeGuard, resourceSet);
private void doLinkingInGroup(GroupNode group,
List<NodeType> groupElements = new ArrayList<>(group.getElements());
for (NodeType groupElement : groupElements) {
if (groupElement instanceof IncludeNode include) {
includeResource(new GroupIncludeTarget(group), include, circularIncludeGuard, resourceSet);
} else if (groupElement instanceof GroupNode childGroup) {
doLinkingInGroup(childGroup, circularIncludeGuard, resourceSet);
private void doLinkingInContainer(ContainerNode container,
List<NodeType> containerElements = new ArrayList<>(container.getElements());
for (NodeType containerElement : containerElements) {
if (containerElement instanceof IncludeNode include) {
includeResource(new ContainerIncludeTarget(container), include, circularIncludeGuard, resourceSet);
} else if (containerElement instanceof GroupNode childGroup) {
private void doLinkingInSoftwareSystem(SoftwareSystemNode softwareSystem,
ArrayList<NodeType> softwareSystemElements = new ArrayList<>(softwareSystem.getElements());
for (NodeType softwareSystemElement : softwareSystemElements) {
if (softwareSystemElement instanceof IncludeNode include) {
includeResource(new SoftwareSystemIncludeTarget(softwareSystem), include, circularIncludeGuard, resourceSet);
} else if (softwareSystemElement instanceof GroupNode childGroup) {
private void includeResource(IncludeTarget includeTarget,
Model includedModel = resolveInclude(include, circularIncludeGuard, resourceSet);
includeModel(includeTarget, includedModel, include, circularIncludeGuard, resourceSet);
private void includeModel(IncludeTarget includeTarget,
Model includedModel,
IncludeNode includeNode,
List<NodeType> newElements = new ArrayList<>(includeTarget.cloneElements());
int includeNodeIndex = newElements.indexOf(includeNode);
int includeElementIndex = includeNodeIndex;
for (NodeType includedNode : includedModel.getElements()) {
if (includedNode instanceof IncludeNode nestedInclude) {
Model nestedIncludedModel = resolveInclude(nestedInclude, circularIncludeGuard, resourceSet);
Model resolved = resolveModel(nestedIncludedModel);
for (NodeType nestedNode : resolved.getElements()) {
newElements.add(++includeElementIndex, nestedNode);
} else if (!newElements.contains(includedNode)) {
if (includeNodeIndex != -1) {
newElements.add(++includeElementIndex, includedNode);
} else {
newElements.add(includedNode);
newElements.remove(includeNodeIndex);
includeTarget.replaceElements(newElements);
Re: Custom scope provider [message #1859700 is a reply to message #1859699] |
Thu, 22 June 2023 15:03   |
did some experiments with an incremental build test
package org.xtext.example.mydsl.tests;
import java.util.ArrayList;
import java.util.List;
import org.eclipse.lsp4j.Diagnostic;
import org.eclipse.lsp4j.DidChangeTextDocumentParams;
import org.eclipse.lsp4j.DidOpenTextDocumentParams;
import org.eclipse.lsp4j.Position;
import org.eclipse.lsp4j.Range;
import org.eclipse.lsp4j.TextDocumentContentChangeEvent;
import org.eclipse.lsp4j.TextDocumentItem;
import org.eclipse.lsp4j.VersionedTextDocumentIdentifier;
import org.eclipse.xtext.ide.server.UriExtensions;
import org.eclipse.xtext.testing.AbstractLanguageServerTest;
import org.eclipse.xtext.util.Strings;
import org.eclipse.xtext.xbase.lib.Extension;
import org.eclipse.xtext.xbase.lib.IterableExtensions;
import org.eclipse.xtext.xbase.lib.ObjectExtensions;
import org.eclipse.xtext.xbase.lib.Procedures.Procedure1;
import org.junit.jupiter.api.Test;
import org.junit.jupiter.api.Assertions;
import com.google.common.collect.Iterables;
import com.google.common.collect.Lists;
import com.google.inject.Inject;
public class DemoTest extends AbstractLanguageServerTest {
public DemoTest() {
super("mydsl");
@Inject
@Extension
private UriExtensions _uriExtensions;
@Test
public void testIncrementalBuild() {
String _uriString = this._uriExtensions.toUriString(this.root.toURI().normalize());
initialize();
open(_uriString + "a.mydsl", "Hello A!");
open(_uriString + "b.mydsl", "Hello B from A!");
List<Diagnostic> problems = problems();
Assertions.assertTrue(problems.size() == 0, problems.toString());
TextDocumentContentChangeEvent c1 = new TextDocumentContentChangeEvent();
c1.setRange(new Range(new Position(0, 0), new Position(0, 0)));
c1.setText("Hello C from B!");
ArrayList<TextDocumentContentChangeEvent> changes = Lists.newArrayList(c1);
change(_uriString + "b.mydsl", 2, changes);
TextDocumentContentChangeEvent c2 = new TextDocumentContentChangeEvent();
c2.setRange(new Range(new Position(0, 0), new Position(0, 0)));
c2.setText("Hello D from Does_Not_Exist!");
changes = Lists.newArrayList(c2);
change(_uriString + "b.mydsl", 3, changes);
Assertions.assertTrue(problems.size() == 1, problems.toString());
System.out.println(problems.toString());
protected void change(final String fileUri, int v, List<TextDocumentContentChangeEvent> changes) {
DidChangeTextDocumentParams p = new DidChangeTextDocumentParams();
VersionedTextDocumentIdentifier i = new VersionedTextDocumentIdentifier();
i.setUri(fileUri);
i.setVersion(v);
p.setTextDocument(i);
p.setContentChanges(changes);
this.languageServer.didChange(p);
private List<Diagnostic> problems() {
return Lists.newArrayList(IterableExtensions.flatten(getDiagnostics().values()));
Re: Custom scope provider [message #1859749 is a reply to message #1859717] |
Sat, 24 June 2023 16:15  |
Hi again, I spent some additional time today and I've realized I'm using Xtext completely wrong way... decide to review my DSL definition and do it correctly this time ;) Thank you again for your help.
Current Time: Mon Sep 22 13:42:07 EDT 2025
Powered by FUDForum. Page generated in 0.05600 seconds
