Home » Newcomers » Newcomers » "open the debug view" (Debugging )
"open the debug view" [message #1859669] Wed, 21 June 2023 15:24 Go to next message
As the message says, for the interactive console in debug mode, you need to have a frame selected -- this is the stack frame on the debug view (so, open the debug view and select the frame on which the commands you execute should be evaluated).
Excuse my ignorance - the above calls l for " open the debug view "
When I do "Run->Run" there is no "debug " nowhere.
Are they referring to "Debug" tab as "view " ?
how do I " open the debug view " ?
In 2022-12 ?
PS
I will not ask how did I get into " interactive" (console mode ?) whatever the term is for.
Update
I can get "Debug" view, still not sure how to consistently get into "interactive console ".
[Updated on: Wed, 21 June 2023 16:08] by Moderator
Re: "open the debug view" [message #1859774 is a reply to message #1859669] Mon, 26 June 2023 12:37 Go to previous messageGo to next message
Again, this seems like something specific to PyDev. https://www.pydev.org/manual_adv_interactive_console.html#starting-the-interactive-console
Re: "open the debug view" [message #1859775 is a reply to message #1859774] Mon, 26 June 2023 19:44 Go to previous messageGo to next message
I have taken a break from coding... Unfortunately I am back to " how to make this consistent / repeatable"....
I am currently running the cloned Python code and cannot get it back to run it in debug mode.
Ever since I got it running I always had "console" however I have not found any specific documentation about it
I am trying to stay on one problem at a time, but it is not easy , I am actually convinced that Eclipse and Python do not work well together - but I am repeating myself...
O really believe that there should be a simple and ONLY ONE way to "clone and debug " Python code in Eclipse , there are multiple paths to accomplish same
and NONE of them works repeatably.
I'll take a look at the link, but at this time I need to "put Eclipse BACK into debug Python code using breakpoints" .
Re: "open the debug view" [message #1860384 is a reply to message #1859775] Wed, 02 August 2023 09:09 Go to previous message
Don't worry, it can be a bit confusing. Yeah, they're talking about the "Debug" tab, and it's kinda like a "view." To open the Debug view, go to "Window" > "Show View" > "Debug."
For the "interactive console," while debugging, you'll find it in the Debug perspective, usually at the bottom. If you can't see it, try dragging the tabs around a bit.
[Updated on: Thu, 03 August 2023 08:41] by Moderator
Previous Topic:Where to ask questions about the XML Editor?
Next Topic:Failed to execute MI command
Current Time: Sun Jul 27 11:12:41 EDT 2025
Powered by FUDForum. Page generated in 0.06201 seconds
