Home » Newcomers » Newcomers » Eclipse Error with Repast Simphony(An internal error occurred during: "Requesting Java AST from selection". 'boolean com.ibm.icu.text.UTF16.isSurrogate(char)')
Eclipse Error with Repast Simphony [message #1859613] Tue, 20 June 2023 05:09 Go to next message
Hey Guys,
Im new to this forum, so if i posted under the wrong Topic, please correct me.
To the Problem:
I installed Repast Simphony (An Agent based Simulation Software)just like its descripted in the quick start Guide: repast.github.io/quick_start.html
And the i tried to start coding my first Simulation, but instantly when i create a new Class (Java) i get the Problem Message:
"An internal error occurred during: "Requesting Java AST from selection".
'boolean com.ibm.icu.text.UTF16.isSurrogate(char)'"
This only happens when im in the Skript. When i close it and only see the Package Explorer everything is fine.
I've tried a number of things like checking if the Project isnt encoded in UTF8 or ive tried to update eclipse(which failed).
Does Anyone know, what might cause this Problem, and hoh i can resolve it?
Thanks in advance
Lukas
Re: Eclipse Error with Repast Simphony [message #1859619 is a reply to message #1859613] Tue, 20 June 2023 10:11 Go to previous message
It looks like they depend on an older version of ICU4J where that method has not been removed. So it doesn't sound like their stuff is compatible with the latest Eclipse. Maybe you should look here to ask those folks directly:
https://repast.github.io/support.html
Previous Topic:Eclipse freezes every time after a bit of usage
Next Topic:setup junit in eclipse
Current Time: Fri Nov 07 16:05:51 EST 2025
Powered by FUDForum. Page generated in 0.08148 seconds
