Home » Eclipse Projects » Eclipse Scout » Using Data Objects with standard eclipse scout(Data Objects)
Using Data Objects with standard eclipse scout [message #1859282] Fri, 26 May 2023 04:53 Go to next message
How to use Object Data with Eclipse scout standard effectively,
May purpose is to integrate it int server module to populate data
this is how I done :
public class EmployeeService implements IEmployeeService {
	public EmployeeTablePageData getEmployeeTableData(SearchFilter filter) {
		EmployeeTablePageData pageData = new EmployeeTablePageData();
		Stream<EmployedRecord> allEmployee = BEANS.get(EmployedRepository.class)
				.getAll();
		Iterator<EmployedRecord> employedIter = allEmployee.iterator();
		while (employedIter.hasNext()) {
			EmployedRecord record = (EmployedRecord) employedIter.next();
			EmployeeTableRowData row = pageData.createRow();
			row.setEmployedId(record.getEmployedId());
			row.setFirstName(record.getFirstName());
			row.setLastName(record.getLastName());
			row.setExternal(record.getExternal());
			pageData.addRow(row);
		return pageData;
my question is :
is there any better way to do it ?
how to manaage insert and update ?
Re: Using Data Objects with standard eclipse scout [message #1859364 is a reply to message #1859282] Fri, 02 June 2023 06:37 Go to previous message
I found it strenge that the program does not create the additionl Do, restriction and reprository classes, the process were much more easier in my opinion.
Previous Topic:Persistent session (e.g. with cookies)
Next Topic:Is table row height configurable?
Current Time: Mon Nov 03 03:46:32 EST 2025
Powered by FUDForum. Page generated in 0.04942 seconds
