How to papyrus source code development [message #1858104] |
Wed, 15 March 2023 22:31  |
Hello everyone!
The following problems were encountered while downloading the papyrus source code:
1.When using git to pull down the git repository of papyrus, some files failed to pull down because the file name was too long;
2.An error was found importing eclipse while downloading the zip source package;
3.The Papyrus Developer Guide is only a general step. This step does not get you anywhere near the desired result. It does not download the source code or import the eclipse project。
For the above questions, I hope experienced peers, can answer. I would love to be able to download the papyrus source code and compile it to run, preferably with idea。
Thanks everyone in advance。
Re: How to papyrus source code development [message #1858559 is a reply to message #1858125] |
Fri, 07 April 2023 04:53   |
Thanks, I can download the papyrus source correctly.But I ran into a new problem, a strange problem when compiling the papyrus source code,Because we want to develop based on the papyrus source code, we are importing eclipse development tools and still reporting errors. I summarize the following points:
1.In many plugins under the plugins package, the Export-Package parameter in the MANIFEST.MF file under the META-INF will report an error. The package under the src does, and I haven't touched the source code yet;
2.In the features package, <feature id="" version=""> <plugin id=""/> prompts version modification problems in almost all feature.xml. Roughly content for "plug-in reference 'org. Eclipse. Papyrus. Example. Core. Lifecycleevents' has had changed from 1.2.0 the to2.0.0",But almost all version numbers in feature.xml are 0.0.0. I don't know if I can understand this description, actually I should post a picture, but the forum can't do it directly
FUDForum. Page generated in 0.04498 seconds
