Home » Modeling » TMF (Xtext) » Formatting: respect newlines
Formatting: respect newlines [message #1857028] Fri, 13 January 2023 14:30 Go to next message
Simon Cockx is currently offline Simon CockxFriend
Member
Suppose I'm writing a formatter for an expression language, and I would like to allow two ways of writing an expression.
In the following example, the `extract` operator should either be preceded by a single space or it should start on a new line.
expr extract prop
expr
    extract prop
However, if it starts on a new line, I would like to add indentation. Is it possible to express this somehow?
Examples of reformatting:
expr
extract
prop
expr
    extract prop
expr        extract
prop
expr extract prop
expr
            extract prop
expr
    extract prop
[Updated on: Fri, 13 January 2023 14:35]
Report message to a moderator
Re: Formatting: respect newlines [message #1857031 is a reply to message #1857028] Fri, 13 January 2023 14:54 Go to previous messageGo to next message
Christian Dietrich is currently offline Christian DietrichFriend
You could read the node model in the formatter, check for nl,
Then if else
Need professional support for Xtext, Xpand, EMF?
Go to: https://www.itemis.com/en/it-services/methods-and-tools/xtext
Twitter : @chrdietrich
Re: Formatting: respect newlines [message #1857033 is a reply to message #1857031] Fri, 13 January 2023 15:47 Go to previous message
Member
Slide 138 of https://www.slideshare.net/meysholdt/xtexts-new-formatter-api covered this, thanks. :)
Basically I can do something like
if (extractExpression.regionFor.keyword("extract").previousHiddenRegion.isMultiline) {
} else {
Great stuff!
Previous Topic:exec-maven-plugin with Xtext
Next Topic:How to implement Formatter maxLineWidth?
Current Time: Tue Mar 28 16:24:09 GMT 2023
Powered by FUDForum. Page generated in 0.02227 seconds
