exec-maven-plugin with Xtext [message #1856950] |
Tue, 10 January 2023 16:06 |
Simon Cockx Messages: 69 Registered: October 2021 |
Member |
Is there a way of configuring `exec-maven-plugin` to work with Xtext/Tycho?
I have a main file `GenerateTmGrammar` that needs grammar access to my DSL, i.e., it needs to run
Injector inj = new MyDSLStandaloneSetup().createInjectorAndDoEMFRegistration();
MyDSLGrammarAccess grammarAccess = inj.getInstance(MyDSLGrammarAccess.class);
Grammar grammar = grammarAccess.getGrammar();
Set<String> keywords = GrammarUtil.getAllKeywords(grammar);
However, when running a `mvn clean install` on the parent project, I'm getting the following error:
An exception occurred while executing the Java class. com.google.common.util.concurrent.UncheckedExecutionException: java.lang.SecurityException: class "org.eclipse.core.runtime.OperationCanceledException"'s signer information does not match signer information of other classes in the same package
Interestingly, I'm not getting this error when I run `mvn clean install` on the actual submodule containing `GenerateTmGrammar.java`.
Before I imported anything related to Xtext the plugin was running fine.
Does anybody have experience with setting this up? Any solutions/workarounds?
`exec-maven-plugin` configuration:
<plugin>
<groupId>org.codehaus.mojo</groupId>
<artifactId>exec-maven-plugin</artifactId>
<version>3.1.0</version>
<executions>
<execution>
<id>Generate TextMate grammar json file</id>
<phase>prepare-package</phase>
<goals>
<goal>java</goal>
</goals>
<configuration>
<mainClass>com.example.mydsl.ide.textmate.GenerateTmLanguage</mainClass>
<arguments>
<argument>${project.basedir}/mydsl.tmLanguage.yaml</argument>
<argument>${project.basedir}/src-gen/syntaxes/mydsl.tmLanguage.json</argument>
</arguments>
<classpathScope>compile</classpathScope>
</configuration>
</execution>
</executions>
</plugin>
Note that I've added `<classpathScope>compile</classpathScope>`. Before that, it wasn't finding my dependency on SnakeYAML, which I added to the target file of my project. I'm not sure why.
[Updated on: Tue, 10 January 2023 16:32] Report message to a moderator
Re: exec-maven-plugin with Xtext [message #1856951 is a reply to message #1856950] |
Tue, 10 January 2023 16:12 |
have no idea but
this looks like an inconsistent use of ecore.runtime and equinox.common.
by using matching explicit versions for both the problem should vanish
Twitter : @chrdietrich
Re: exec-maven-plugin with Xtext [message #1856967 is a reply to message #1856951] |
Wed, 11 January 2023 08:59 |
Member |
Thanks! Adding these two dependencies to the plugin actually solved it.
After that, I noticed that I actually had some dependencies defined in Maven that were conflicting with Tycho. Once I replaced all explicit Maven dependencies with the corresponding target platform/Tycho dependencies, I could run exec-maven-plugin without the additional dependencies. So the actual cause was a problem in my Maven configuration.
[Updated on: Wed, 11 January 2023 09:00] Report message to a moderator
Re: exec-maven-plugin with Xtext [message #1856970 is a reply to message #1856967] |
Wed, 11 January 2023 09:57 |
Member |
Hm, although now I'm getting a `FileSystemNotFoundException: Provider "bundleresource" not installed` exception while running unit tests. @Christian Dietrich, do you have an idea in which dependency file system support for `bundleresource` is defined?
Tests are fine when I run them in Eclipse.
[Updated on: Wed, 11 January 2023 10:10] Report message to a moderator
FUDForum. Page generated in 0.03623 seconds
