Home » Newcomers » Newcomers » eclipse fails to start after windows laptop restart(issues with eclipse start after machine restart)
eclipse fails to start after windows laptop restart [message #1856791] Tue, 03 January 2023 04:41 Go to next message
bln prasad is currently offline bln prasadFriend
I'm consistently seeing the issue where eclipse fails to start after my (windows) laptop restart. ive moved to latest version jee-2022-12 but still issue is seen. the only way to recover is fresh install of same version.
it always throws this error on fail. can you please do the needful to fix same.
it creates 7 err log files. just pasting start and end of it below.
!SESSION 2023-01-03 09:38:40.644 -----------------------------------------------^M
eclipse.buildId=4.26.0.20221201-1200^M
java.version=17.0.5^M
java.vendor=Oracle Corporation^M
BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=en_IN^M
Framework arguments: -product org.eclipse.epp.package.jee.product^M
Command-line arguments: -os win32 -ws win32 -arch x86_64 -product org.eclipse.epp.package.jee.product^M
^M
!ENTRY org.apache.felix.scr 4 0 2023-01-03 09:38:41.720^M
!MESSAGE FrameworkEvent ERROR^M
!STACK 0^M
org.osgi.framework.BundleException: Could not resolve module: org.apache.felix.scr [76]
Unresolved requirement: Import-Package: org.osgi.service.cm; version="[1.6.0,2.0.0)"; resolution:="optional"
Unresolved requirement: Import-Package: org.osgi.service.metatype; version="[1.2.0,2.0.0)"; resolution:="optional"
Unresolved requirement: Import-Package: org.osgi.service.component.runtime.dto; version="[1.5.0,2.0.0)"
-> Export-Package: org.osgi.service.component.runtime.dto; bundle-symbolic-name="org.osgi.service.component"; bundle-version="1.5.0.202109301733"; version="1.5.0"; uses:="org.osgi.dto,org.osgi.framework.dto"
org.osgi.service.component [889]
Unresolved requirement: Import-Package: org.osgi.util.promise; version="[1.0.0,2.0.0)"
-> Export-Package: org.osgi.util.promise; bundle-symbolic-name="org.osgi.util.promise"; bundle-version="1.2.0.202109301733"; version="1.2.0"; uses:="org.osgi.util.function"
org.osgi.util.promise [904]
Unresolved requirement: Import-Package: org.osgi.util.function; version="[1.1.0,2.0.0)"
Unresolved requirement: Import-Package: org.osgi.service.component.runtime; version="[1.5.0,1.6.0)"
-> Export-Package: org.osgi.service.component.runtime; bundle-symbolic-name="org.osgi.service.component"; bundle-version="1.5.0.202109301733"; version="1.5.0"; uses:="org.osgi.framework,org.osgi.service.component.runtime.dto,org.osgi.util.promise"
Unresolved requirement: Import-Package: org.osgi.service.component; version="[1.5.0,1.6.0)"
-> Export-Package: org.osgi.service.component; bundle-symbolic-name="org.osgi.service.component"; bundle-version="1.5.0.202109301733"; version="1.5.0"; uses:="org.osgi.framework"
^M
at org.eclipse.osgi.container.Module.start(Module.java:463)^M
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel$2.run(ModuleContainer.java:1852)^M
at org.eclipse.osgi.internal.framework.EquinoxContainerAdaptor$1$1.execute(EquinoxContainerAdaptor.java:136)^M
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1845)^M
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1788)^M
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.doContainerStartLevel(ModuleContainer.java:1750)^M
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1672)^M
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1)^M
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:234)^M
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:345)^M
^M
!ENTRY org.eclipse.equinox.event 4 0 2023-01-03 09:38:41.749^M
!STACK 0^M
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.equinox.event [350]
*************** end **********************
^M
!ENTRY org.eclipse.osgi 4 0 2023-01-03 09:38:50.976^M
!MESSAGE Application error^M
!STACK 1^M
java.lang.RuntimeException: Application "org.eclipse.ui.ide.workbench" could not be found in the registry. The applications available are: org.eclipse.ant.core.antRunner, org.eclipse.datatools.connectivity.console.profile.StorageFileEditor, org.eclipse.emf.codegen.CodeGen, org.eclipse.emf.codegen.JMerger, org.eclipse.emf.codegen.ecore.Generator, org.eclipse.emf.importer.ecore.Ecore2GenModel, org.eclipse.emf.importer.java.Java2GenModel, org.eclipse.emf.importer.rose.Rose2GenModel, org.eclipse.equinox.app.error, org.eclipse.jdt.apt.core.aptBuild, org.eclipse.jdt.core.JavaIndexer, org.eclipse.jdt.core.JavaCodeFormatter, org.eclipse.pde.junit.runtime.uitestapplication, org.eclipse.pde.junit.runtime.coretestapplication, org.eclipse.pde.junit.runtime.coretestapplicationnonmain, org.eclipse.pde.junit.runtime.nonuithreadtestapplication.^M
at org.eclipse.equinox.internal.app.EclipseAppContainer.startDefaultApp(EclipseAppContainer.java:252)^M
at org.eclipse.equinox.internal.app.MainApplicationLauncher.run(MainApplicationLauncher.java:33)^M
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:136)^M
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:104)^M
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:402)^M
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:255)^M
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native Method)^M
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:77)^M
at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)^M
at java.base/java.lang.reflect.Method.invoke(Method.java:568)^M
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:659)^M
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:596)^M
at org.eclipse.equinox.launcher.Main.run(Main.java:1467)^M
Re: eclipse fails to start after windows laptop restart [message #1856793 is a reply to message #1856791] Tue, 03 January 2023 06:26 Go to previous messageGo to next message
Nitin Dahyabhai is currently online Nitin DahyabhaiFriend
How was this originally installed, where was it installed to, and how are you reinstalling it?
Nitin Dahyabhai
Eclipse Web Tools Platform
Re: eclipse fails to start after windows laptop restart [message #1856794 is a reply to message #1856793] Tue, 03 January 2023 06:49 Go to previous messageGo to next message
i used "eclipse-inst-jre-win64 " installer to install for my java development by choosing "java EE IDE". it installs under my C:\user location.
for resinstall i use the same and installer chooses different folder by adding suffix ex: jee-2022-123, jee-2022-124 etc.
Re: eclipse fails to start after windows laptop restart [message #1856797 is a reply to message #1856794] Tue, 03 January 2023 08:56 Go to previous messageGo to next message
I wonder if some of the values in the eclipse.ini are off? Mine, for example, look like this
-startup
plugins/org.eclipse.equinox.launcher_1.6.400.v20210924-0641.jar
--launcher.library
D:\Users\merks\.p2\pool\plugins\org.eclipse.equinox.launcher.win32.win32.x86_64_1.2.400.v20211117-0650
-product
org.eclipse.epp.package.committers.product
-showsplash
D:\Users\merks\.p2\pool\plugins\org.eclipse.epp.package.common_4.22.0.20211202-1200
--launcher.defaultAction
openFile
--launcher.appendVmargs
-vm
C:\Program Files\Java\jdk-17.0.5+8\bin
You might also try to run eclipse.exe -clean to see if that helps.
Ed Merks
Re: eclipse fails to start after windows laptop restart [message #1856803 is a reply to message #1856797] Tue, 03 January 2023 12:26 Go to previous messageGo to next message
interesting. i never compared working and non working version. here is the difference. i've not updated it. so not sure from where its getting updated. Do you think thats what making difference? if yes then how do i control it?
  • Attachment: cfg.diff.png
    (Size: 85.27KB, Downloaded 32 times)
Re: eclipse fails to start after windows laptop restart [message #1856814 is a reply to message #1856803] Wed, 04 January 2023 08:09 Go to previous messageGo to next message
Neither look correct to me. Nothing should be referencing something in your temp storage and if you are using a bundle pool (the default) the paths must be absolute referencing the location of the pool. It's as if you are using the temp storage as the bundle pool.
What's in your <home>/.p2/pools.info file? Mine contains 'D:\Users\merks\.p2\pool' hence the eclipse.ini entries pointing into that pool. In the installer, this is managed via the menu in the upper right's "Bundle Pools...".
If you have no working installations that you need to preserve, I'd suggest delete the <home>/.eclipse and <home>/.p2 and start a fresh clean installation without changing default locations...
Ed Merks
Re: eclipse fails to start after windows laptop restart [message #1856821 is a reply to message #1856814] Wed, 04 January 2023 10:03 Go to previous messageGo to next message
sure. I'll try this out and monitor for few days
Re: eclipse fails to start after windows laptop restart [message #1856913 is a reply to message #1856821] Mon, 09 January 2023 07:54 Go to previous message
Sanjeev Rao is currently offline Sanjeev RaoFriend
It looks like Eclipse is having a problem starting due to issues with some of the installed plugins. The error message mentions "unresolved requirements" for several packages, which suggests that the required packages are not being exported by the corresponding bundles.
One potential cause of this issue could be conflicts between different versions of the same package that are being imported and exported by different bundles. It could also be that some of the required packages are not being exported by any installed bundle at all.
One way to troubleshoot this issue would be to try and identify which bundles are exporting the required packages and whether there are any version conflicts. You can do this by looking at the "Import-Package" and "Export-Package" headers in the MANIFEST.MF files of the bundles.
You could also try disabling some of the installed plugins and seeing if that helps resolve the issue. If disabling a particular plugin helps, then that plugin may be causing the issue. In that case, you may want to try updating the plugin to the latest version or contacting the plugin's developers for further assistance.
Another potential solution could be to try cleaning the Eclipse configuration. You can do this by going to the Eclipse installation directory and deleting the "configuration" folder. This will reset the Eclipse configuration to the default, which might fix the issue. However, note that this will also reset any custom settings you have made in Eclipse, so you may need to set these up again after cleaning the configuration.
Let me know if this works for you.
Previous Topic:I want to contribute via GSoC 2023
Next Topic:Help color wont turn random
Current Time: Wed Mar 29 01:57:36 GMT 2023
Powered by FUDForum. Page generated in 0.03087 seconds
