Connecting to broker with username and password using mqtt.js [message #1856416] |
Thu, 08 December 2022 15:36  |
I am using JavaScript / mqtt.js to connect to a Mosquitto broker.
I had everything working, and then I upgraded to the Mosquitto version 2.0.15, and now I cannot connect to the broker.
Could you read the following, and see if you have any suggestions, plase.
Garrett
OLD SET UP
I had v1.6.9 Mosquitto installed and running on Ubuntu (in Google Cloud).
I was able to communicate with the broker using:
(a) desktop web client
(b) MQTT Explorer
(c) JavaScript using mqtt.js
NEW SETUP
I upgraded to latest Mosquitto version 2.0.15.
I had to create a username and password, so I used the instructions here:
https://mosquitto.org/documentation/authentication-methods/
I edited the mosquito.conf file, so it knows about the password file.
I restarted the VM and then started Mosquitto.
WHAT STILL WORKS
Now, I am able to communicate with the broker (with username/password) using:
(b) MQTT Explorer
But not
mqtt.js connect options
In JavaScript, my connect options used to be of the form (for v1.6.9):
const connection_options = {
port: 1883,
host: host,
clientId: client_id,
clean: true,
keepalive: false,
reconnectPeriod: 5000
where host is the IP address of the machine
And are now of the form (for v2.0.15):
port: 1883,
host: host,
username: 'user',
password: 'password',
clean: true,
keepalive: false,
I have double checked the username / password values etc.
So, the only thing I changed was adding the username and password, but I can no longer connect with the broker.
The desktop web client, MQTT Explorer and the JavaScript/mqtt.js are all using the same IP address, same port, same username and password.
Any help / suggestions greatly appreciated
Re: Connecting to broker with username and password using mqtt.js [message #1856436 is a reply to message #1856416] |
Fri, 09 December 2022 14:32  |
I solved the issue.
Once I turned logging on, I got some very helpful information
Note: I hadn't turned logging on because I an new to mosquitto, linux, mqtt - and I hadn't worked out how to do it!
What I saw, when I tried to connect with mqtt.js was:
Bad socket read/write on client my_publisher: Invalid arguments provided.
I found this on the github forum:
https://github.com/eclipse/mosquitto/issues/2462
I have only skimmed through it I will re-read the full thing later.
The issue is the keep alive (seconds) value.
If it is set 0, I couldn't connect.
Once I set it to a non-zero value, I can connect.
I think there is a different way to get around this, a setting to allow keep alive to be zero, but I will look into this later.
I think it only affects certain versions of Mosquitto (and obviously the latest version).
FUDForum. Page generated in 0.07544 seconds
