Home » Modeling » TMF (Xtext) » Xcore and mwe2(Is it possible to use Xcore in our workflow?)
Xcore and mwe2 [message #1856365] Wed, 07 December 2022 10:45 Go to next message
we use MWE2 workflows to generate from ecore to Java classes and run modification onto them.
Is it possible to use Xcore to edit the model.
Then on save instead of generating code, it shall just save/export to an ecore/genmodel file?
What setup is needed for this? Is there an existing description?
If this is possible, I could run the mwe2 workflow afterwards, as usual I do today with the ecore/genmodel file.
Frank
Re: Xcore and mwe2 [message #1856367 is a reply to message #1856365] Wed, 07 December 2022 10:59 Go to previous messageGo to next message
i have zero clue on xcore and mwe2 but maybe you can check
https://github.com/eclipse/xtext-maven/tree/master/org.eclipse.xtext.maven.plugin/src/test/resources/it/generate/xcore-lang
and (dont know how up to date this is and what it exactly does)
https://github.com/cdietrich/xcore-maven-example
https://github.com/cdietrich/xtext-ecore-xcore
Re: Xcore and mwe2 [message #1856373 is a reply to message #1856367] Wed, 07 December 2022 12:48 Go to previous messageGo to next message
I too have limited knowledge on xcore but understand it to be *.ecore plus *.genmodel with a friendly Xtext editor.
Since MWE2 supports custom beans, you can certainly develop a suitable one if no one has one already available. Adapting the standard (or else the OCL) Ecore GenModel bean is probably a good start.
Ed Willink
Re: Xcore and mwe2 [message #1856382 is a reply to message #1856373] Thu, 08 December 2022 01:46 Go to previous message
You can directly use an Xcore model in an Xtext grammar. But I'm not sure what "modifications" you have to make; perhaps operations with bodies are sufficient for that purpose.
Previous Topic:Dependency injection of ResourceDescriptionsProvider failed
Next Topic:Code completion is leading to validation execution in language server
Current Time: Fri Oct 24 07:30:02 EDT 2025
Powered by FUDForum. Page generated in 0.04637 seconds
