Using custom URI's [message #1855985] |
Mon, 14 November 2022 09:30  |
With Xtext 2.25, we were using custom URI's of the form `ws:/some/uri` and `scm:/some/other/uri` for which we implemented a custom way of resolving them. However, since upgrading to Xtext 2.27 and LSP4J 0.14.0, we have issues were Xtext tries to read the URI's itself.
I am guessing that our current approach (something I didn't write myself :) ) was somewhat hacky, and didn't really integrate well with Xtext. What is currently the best approach?
I have been looking at this thread:
https://www.eclipse.org/forums/index.php/t/200704/
It seems very close to what I would like to achieve. What I gathered from this, is that I should define a custom `URIHandler` for each of our custom protocols, and then somehow hook that into the `XtextResourceProvider`. However, it is an old thread, and I can't seem to find `org.eclipse.xtext.ui.resource.IResourceSetProvider` anywhere. Is there a new way of doing this?
Kind regards
Simon
[Updated on: Mon, 14 November 2022 09:36] by Moderator
Re: Using custom URI's [message #1855987 is a reply to message #1855986] |
Mon, 14 November 2022 10:04   |
I'll try to give you the broad lines. I'm not sure if this is all relevant though, and I fear we have some tech debt. What I basically would like to do is tell Xtext how to resolve a particular URI.
Our infrastructure high-level looks like this:
On the backend we use Xtext 2.27.0. (was 2.25.0)
On the frontend we use Monaco 0.34.1 (was 0.19.3) (https://github.com/microsoft/monaco-editor)
For communication we use LSP4J 0.14.0. (was 0.9.0)
We use URI's with custom protocols. Each protocol basically points to a different root folder on the file system.
The upgrade broke several things.
1. When calling the LSP method `initialize`, we noticed the backend now tries to build all files in the workspace. Before this, we handled the build process ourselves after LSP initialization. However, now it does so by running a file scanner on the given workspace URI (for which we have a protocol ws:/), which completely ignores the protocol and interprets the URI as a local file path.
=> our solution was to hook into `IFileSystemScanner` and translate the `ws:/` URI's to regular `file:/` URI's.
2. Our build process relies on receiving resources with a URI that uses our custom protocols. However, the `IFileSystemScanner` outputs `file:/` URI's, which then crashes the build system.
=> our hacky solution was to hook into `ResourceAwareFSAFactory` and convert these URI's back into the ones we expect.
3. The command `Search symbol across workspace` triggers a call to `XtextResourceSet::getURIConverter().createInputStream`, which also doesn't know how to handle our custom URI's.
I find my current approach somewhat dirty, and I was hoping to find a single place where I could override the behaviour of URI resolution. Hence, my original question.
[Updated on: Mon, 14 November 2022 10:12] by Moderator
FUDForum. Page generated in 0.03474 seconds
