| Getting project is not open exception. [message #1855861] |
Tue, 08 November 2022 00:52 |
Recently updated eclipse version from 2020-09R to 2022-09R.
Started getting this exception while running Junit tests. The exception is not detailed, and I'm unable to find out from where in my code this exception is originating.
!MESSAGE Project 'TestProject' is not open.
!STACK 0
java.lang.Exception: Project 'TestProject' is not open.
at org.eclipse.core.internal.resources.ResourceException.provideStackTrace(ResourceException.java:42)
at org.eclipse.core.internal.resources.ResourceException.<init>(ResourceException.java:38)
at org.eclipse.core.internal.resources.Project.checkAccessible(Project.java:153)
at org.eclipse.core.internal.resources.Resource.checkAccessibleAndLocal(Resource.java:210)
at org.eclipse.core.internal.resources.Resource.getPersistentProperty(Resource.java:1135)
at org.eclipse.egit.core.internal.util.ResourceUtil.getGitProvider(ResourceUtil.java:280)
at org.eclipse.egit.core.project.RepositoryMapping.getProjectData(RepositoryMapping.java:330)
at org.eclipse.egit.core.project.RepositoryMapping.findMapping(RepositoryMapping.java:356)
at org.eclipse.egit.core.project.RepositoryMapping.getMapping(RepositoryMapping.java:313)
at org.eclipse.egit.core.internal.start.WorkspaceConnector$CheckProjectsToShare.visitConnect(WorkspaceConnector.java:315)
at org.eclipse.egit.core.internal.start.WorkspaceConnector$CheckProjectsToShare.run(WorkspaceConnector.java:293)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63)
Upon further debugging found out that a file is not found when I invoke the org.eclipse.core.resources.IWorkspaceRoot.delete(boolean, boolean, IProgressMonitor) method with the following message.
Quote:File not found: /home/sanjay/junit-workspace/.metadata/.plugins/org.eclipse.egit.core/.org.eclipse.egit.core.cmp/.settings/org.eclipse.core.resources.prefs.
What's going on here? The tests are running as excepted but I'm concerned about this exception.
FUDForum. Page generated in 0.33412 seconds
