Home » Eclipse Projects » EGit / JGit » Discussion on default values of "Configure upstream for push and pull"
Discussion on default values of "Configure upstream for push and pull" [message #1855848] Mon, 07 November 2022 11:58 Go to next message
Hi there,
I really prefer creating branches via the History view by right-clicking a commit and using the "Create branch..." command.
However, whenever a remote-tracking branch points to that commit, the option "Configure upstream for push and pull" is checked by default and I have to remember unchecking it to prevent the new branch from getting linked to that remote branch.
I've forgotten this a few times and then pushed to the wrong branch.
What is the reason why this option is checked by default in this use case (we're not talking about a checkout use case, where the reason is obivous)?
Cheers
Rice
Re: Discussion on default values of "Configure upstream for push and pull" [message #1856442 is a reply to message #1855848] Fri, 09 December 2022 18:48 Go to previous messageGo to next message
This is done since in order to push a new commit to an upstream branch most git users typically
start a new local branch from this upstream branch's remote tracking branch in their clone in order
to develop this commit.
Re: Discussion on default values of "Configure upstream for push and pull" [message #1856626 is a reply to message #1856442] Mon, 19 December 2022 04:19 Go to previous message
Hi Matthias,
isn't this the typical "checkout", which has a dedicated context menu entry?
For checkout, I totally agree - this is what you want for a checkout.
But I mean the "Create branch" use case. The same dialog is used in both use cases.
Previous Topic:Wrong file after jgit apply command
Next Topic:Behavior changed when pushing a new branch?
Current Time: Mon Oct 27 11:08:19 EDT 2025
Powered by FUDForum. Page generated in 0.26264 seconds
