Home » Eclipse Projects » Memory Analyzer » Unable to delete heap dump file after getting ISnapshot object
Unable to delete heap dump file after getting ISnapshot object [message #1855123] Thu, 29 September 2022 05:20 Go to next message
I am using Eclipse MAT APIs to analyze the heap dump file. I am calling SnapshotFactory.openSnapshot() and passing the heap dump file as an argument to this method and getting the snapshot object.
Once the snapshot object is returned I am trying to delete the heap dump file from the disk. But I am getting the below error message while deleting a file. It looks like the file is still open in SnapshotFactory.openSnapshot() method.
Error - java.nio.file.FileSystemException: <HeapDump-File-Path>: The process cannot access the file because it is being used by another process
Here is a sample code:
try {
    String filePath = "HEAP_DUMP_PATH";
    File hdFile = new File(filePath);
    ISnapshot snapshot = SnapshotFactory.openSnapshot(hdFile,
					new HashMap<String, String>(), new SysOutProgressListener());
    Path path = Paths.get(filePath);
    Boolean isDeleted = Files.deleteIfExists(path);
} catch(Exception e) {
     e.printStackTrace();
[Updated on: Thu, 29 September 2022 05:27] by Moderator
Re: Unable to delete heap dump file after getting ISnapshot object [message #1855125 is a reply to message #1855123] Thu, 29 September 2022 05:37 Go to previous message
I found the solution. I need to call SnapshotFactory.dispose(ISnapshot) method to release the resources.
Previous Topic:Issues using IBM Seamer DTFJ
Next Topic:Unable to build locally on linux
Current Time: Thu Oct 23 03:45:03 EDT 2025
Powered by FUDForum. Page generated in 0.23715 seconds
