| efxclipse 3.x and the path to 4.0 [message #1855085] |
Wed, 28 September 2022 03:51  |
The following is only important for those consuming the runtime of e(fx)clipse.
We think it is now the time to think about the next steps for e(fx)clipse and we want to layout out what we (BestSolution who does most of the work) think is best for the future of the project.
We've already started a long time ago an effort remove PDE/maven-tycho from the runtime (build) and make our projects PURE maven artifacts. After the release of e(fx)clipse 3.9 we will concentrate on moving this forward which is going to be easier (as it used to be) because the Eclipse Platform releases all its bits to maven-central since some time.
The plan for the main-branch looks like this:
- Merge the latest changes from 3.x-branch to master
- Restructure the projects (eg split projects, ...)
- Remove Java-8 support
We will still provide a target platform so you can still use Eclipse-PDE for development but our main target will be pure maven.
FUDForum. Page generated in 0.04019 seconds
