Issue with p2 published [message #1854764] |
Thu, 08 September 2022 08:09 |
While publishing bundles for update site,I get below error. Could you please help ?
!ENTRY org.eclipse.equinox.p2.publisher.eclipse 2 0 2022-09-08 11:51:08.826
!MESSAGE An error has occurred while adding the bundle /<PATH>/org.eclipse.jetty.websocket.core.client_10.0.11.jar.
!STACK 0
org.osgi.framework.BundleException: Invalid manifest header Import-Package: "java.io" : Cannot specify java.* packages in Import/Export headers "java.io"
at org.eclipse.osgi.internal.resolver.StateBuilder.checkImportExportSyntax(StateBuilder.java:826)
at org.eclipse.osgi.internal.resolver.StateBuilder.validateHeaders(StateBuilder.java:214)
at org.eclipse.osgi.internal.resolver.StateBuilder.createBundleDescription(StateBuilder.java:65)
at org.eclipse.osgi.internal.resolver.StateObjectFactoryImpl.createBundleDescription(StateObjectFactoryImpl.java:32)
at org.eclipse.osgi.service.resolver.StateObjectFactory$StateObjectFactoryProxy.createBundleDescription(StateObjectFactory.java:558)
at org.eclipse.equinox.p2.publisher.eclipse.BundlesAction.createBundleDescription(BundlesAction.java:543)
at org.eclipse.equinox.p2.publisher.eclipse.BundlesAction.createBundleDescription(BundlesAction.java:579)
at org.eclipse.equinox.p2.publisher.eclipse.BundlesAction.getBundleDescriptions(BundlesAction.java:901)
at org.eclipse.equinox.p2.publisher.eclipse.BundlesAction.perform(BundlesAction.java:721)
at org.eclipse.equinox.p2.publisher.Publisher$ArtifactProcess.run(Publisher.java:207)
at org.eclipse.equinox.internal.p2.artifact.repository.simple.SimpleArtifactRepository.executeBatch(SimpleArtifactRepository.java:1344)
at org.eclipse.equinox.p2.publisher.Publisher.publish(Publisher.java:231)
at org.eclipse.equinox.p2.publisher.AbstractPublisherApplication.run(AbstractPublisherApplication.java:286)
at org.eclipse.equinox.p2.publisher.AbstractPublisherApplication.run(AbstractPublisherApplication.java:256)
at org.eclipse.equinox.p2.publisher.AbstractPublisherApplication.start(AbstractPublisherApplication.java:320)
at org.eclipse.equinox.internal.app.AnyThreadAppLauncher.run(AnyThreadAppLauncher.java:26)
at java.lang.Thread.run(Thread.java:748)
FUDForum. Page generated in 0.03831 seconds
