Home » Eclipse Projects » Equinox » Issue with org.eclipse.equinox.p2.publisher.FeaturesAndBundlesPublisher(Issue with org.eclipse.equinox.p2.publisher.FeaturesAndBundlesPublisher)
Issue with org.eclipse.equinox.p2.publisher.FeaturesAndBundlesPublisher [message #1854761] Thu, 08 September 2022 06:58 Go to next message
I get below error when I use org.eclipse.equinox.p2.publisher.FeaturesAndBundlesPublisher. Could you please help?
!ENTRY org.eclipse.equinox.p2.publisher.eclipse 2 0 2022-09-08 11:51:08.826
!MESSAGE An error has occurred while adding the bundle /<PATH>/org.eclipse.jetty.websocket.core.client_10.0.11.jar.
!STACK 0
org.osgi.framework.BundleException: Invalid manifest header Import-Package: "java.io" : Cannot specify java.* packages in Import/Export headers "java.io"
        at org.eclipse.osgi.internal.resolver.StateBuilder.checkImportExportSyntax(StateBuilder.java:826)
        at org.eclipse.osgi.internal.resolver.StateBuilder.validateHeaders(StateBuilder.java:214)
        at org.eclipse.osgi.internal.resolver.StateBuilder.createBundleDescription(StateBuilder.java:65)
        at org.eclipse.osgi.internal.resolver.StateObjectFactoryImpl.createBundleDescription(StateObjectFactoryImpl.java:32)
        at org.eclipse.osgi.service.resolver.StateObjectFactory$StateObjectFactoryProxy.createBundleDescription(StateObjectFactory.java:558)
        at org.eclipse.equinox.p2.publisher.eclipse.BundlesAction.createBundleDescription(BundlesAction.java:543)
        at org.eclipse.equinox.p2.publisher.eclipse.BundlesAction.createBundleDescription(BundlesAction.java:579)
        at org.eclipse.equinox.p2.publisher.eclipse.BundlesAction.getBundleDescriptions(BundlesAction.java:901)
        at org.eclipse.equinox.p2.publisher.eclipse.BundlesAction.perform(BundlesAction.java:721)
        at org.eclipse.equinox.p2.publisher.Publisher$ArtifactProcess.run(Publisher.java:207)
        at org.eclipse.equinox.internal.p2.artifact.repository.simple.SimpleArtifactRepository.executeBatch(SimpleArtifactRepository.java:1344)
        at org.eclipse.equinox.p2.publisher.Publisher.publish(Publisher.java:231)
        at org.eclipse.equinox.p2.publisher.AbstractPublisherApplication.run(AbstractPublisherApplication.java:286)
        at org.eclipse.equinox.p2.publisher.AbstractPublisherApplication.run(AbstractPublisherApplication.java:256)
        at org.eclipse.equinox.p2.publisher.AbstractPublisherApplication.start(AbstractPublisherApplication.java:320)
        at org.eclipse.equinox.internal.app.AnyThreadAppLauncher.run(AnyThreadAppLauncher.java:26)
        at java.lang.Thread.run(Thread.java:748)
Re: Issue with org.eclipse.equinox.p2.publisher.FeaturesAndBundlesPublisher [message #1854781 is a reply to message #1854761] Fri, 09 September 2022 15:41 Go to previous messageGo to next message
I answered your cross-post here:
https://www.eclipse.org/forums/index.php/mv/msg/1111555/1854778/#msg_1854778
Re: Issue with org.eclipse.equinox.p2.publisher.FeaturesAndBundlesPublisher [message #1855022 is a reply to message #1854781] Fri, 23 September 2022 15:23 Go to previous message
Sorry - answered to the wrong thread
[Updated on: Fri, 23 September 2022 16:33] by Moderator
Previous Topic:Slow Classloading with many jars on the classpath
Next Topic:Debug logging in org.eclipse.equinox.p2.metadata.repository.mirrorApplication
Current Time: Wed Nov 05 07:47:07 EST 2025
Powered by FUDForum. Page generated in 0.04708 seconds
