Home » Eclipse Projects » Sisu » Error injecting: public org.apache.maven.repository.internal.DefaultVersionResolver: Jenkins plugin(Error injecting: public org.apache.maven.repository.internal.DefaultVersionResolver: Jenkins plugin when using implementation 'org.jenkins-ci.main:maven-plugin:3.8.1')
Error injecting: public org.apache.maven.repository.internal.DefaultVersionResolver: Jenkins plugin [message #1854547] Wed, 24 August 2022 13:00
I am using Jenkins test harness to write unit test for jenkins code. I am facing an injection error. This is my jenkins test and build.gradle file. I tried one solution of using jar of plugin instead of jpi through `testImplementation fileTree(dir: 'tmp/libs', include: ['*.jar'])` but it is giving me the same result(`tmp/libs`) is the location where jar and jpi is generated).
How to solve this issue?
@Test
public void mavenJob1() throws Exception {
MavenModuleSet project = j.createProject(MavenModuleSet.class, "maven");
Maven.MavenInstallation mavenInstallation = new Maven.MavenInstallation("test",
"/usr/local/apache-maven-3.8" + ".5");
project.getDescriptor().getMavenDescriptor().setInstallations(mavenInstallation);
project.setMaven("test");
//project.setScm(new SingleFileSCM("pom.xml", readResourceAsString("pom.xml")));
Path resourceDirectory = Paths.get("src", "test", "resources");
String absolutePath = resourceDirectory.toFile().getAbsolutePath();
project.setCustomWorkspace(absolutePath.concat("/testNgFiles"));
List<Action> actions = getDefaultActions();
j.assertBuildStatus(Result.SUCCESS, project.scheduleBuild2(0, actions.toArray(new Action[0])));
The `build.gradle` dependencies is like this
dependencies {
implementation('org.apache.maven.surefire:surefire-report-parser:3.0.0-M6') {
exclude group: 'commons-io', module: 'commons-io'
implementation 'org.json:json:20140107'
implementation 'com.google.code.findbugs:jsr305:2.0.1'
implementation 'commons-io:commons-io:2.8.0'
implementation 'org.apache.maven.surefire:surefire-logger-api:3.0.0-M7'
implementation 'xerces:xmlParserAPIs:2.6.1'
implementation 'org.jenkins-ci.plugins.workflow:workflow-api:2.37'
implementation 'org.jenkins-ci.plugins.workflow:workflow-job:2.34'
implementation 'org.apache.httpcomponents:httpclient:4.5.8'
implementation 'org.apache.httpcomponents:httpmime:4.3.1'
implementation 'com.google.code.gson:gson:2.8.6'
testImplementation 'org.jenkins-ci.plugins:token-macro:2.12'
testImplementation 'org.jenkins-ci.plugins:matrix-project:1.18'
testImplementation 'org.jenkins-ci.modules:sshd:2.7'
testImplementation 'com.sparkjava:spark-core:2.2'
testImplementation('org.junit.jupiter:junit-jupiter-api:5.9.0')
testRuntimeOnly('org.junit.jupiter:junit-jupiter-engine:5.9.0')
testRuntimeOnly('org.junit.vintage:junit-vintage-engine:5.9.0')
testImplementation('junit:junit:4.13.1')
testRuntimeOnly("org.junit.support:testng-engine:1.0.4")
testImplementation('org.testng:testng:6.14.3')
1) Error injecting: public org.apache.maven.repository.internal.DefaultVersionResolver org.apache.maven.repository.internal.DefaultVersionResolver.setRepositoryEventDispatcher(org.eclipse.aether.impl.RepositoryEventDispatcher)
at ClassRealm[maven, parent: ClassRealm[maven-parent, parent: null]] (via modules: org.eclipse.sisu.wire.WireModule -> org.eclipse.sisu.plexus.PlexusBindingModule)
while locating org.apache.maven.repository.internal.DefaultVersionResolver
while locating java.lang.Object annotated with *
at org.eclipse.sisu.wire.LocatorWiring
while locating org.eclipse.aether.impl.VersionResolver
for the 1st parameter of org.eclipse.aether.internal.impl.DefaultRepositorySystem.<init>(DefaultRepositorySystem.java:131)
while locating org.eclipse.aether.internal.impl.DefaultRepositorySystem
while locating org.apache.maven.artifact.resolver.DefaultArtifactResolver
while locating org.apache.maven.artifact.resolver.ArtifactResolver
while locating org.apache.maven.repository.legacy.LegacyRepositorySystem
while locating org.apache.maven.repository.RepositorySystem
1 error
role: org.apache.maven.repository.RepositorySystem
roleHint:
at org.codehaus.plexus.DefaultPlexusContainer.lookup(DefaultPlexusContainer.java:267)
at org.codehaus.plexus.DefaultPlexusContainer.lookup(DefaultPlexusContainer.java:255)
at org.codehaus.plexus.DefaultPlexusContainer.lookup(DefaultPlexusContainer.java:249)
at hudson.maven.MavenEmbedder.lookup(MavenEmbedder.java:576)
at hudson.maven.MavenEmbedder.getLocalRepository(MavenEmbedder.java:270)
at hudson.maven.MavenEmbedder.buildMavenExecutionRequest(MavenEmbedder.java:166)
at hudson.maven.MavenEmbedder.<init>(MavenEmbedder.java:121)
... 14 more
Caused by: com.google.inject.ProvisionException: Unable to provision, see the following errors:
1 error
at com.google.inject.internal.InternalProvisionException.toProvisionException(InternalProvisionException.java:226)
at com.google.inject.internal.InjectorImpl$1.get(InjectorImpl.java:1053)
at org.eclipse.sisu.inject.LazyBeanEntry.getValue(LazyBeanEntry.java:81)
at org.eclipse.sisu.plexus.LazyPlexusBean.getValue(LazyPlexusBean.java:51)
at org.codehaus.plexus.DefaultPlexusContainer.lookup(DefaultPlexusContainer.java:263)
... 20 more
Caused by: java.lang.IllegalArgumentException: argument type mismatch
at org.eclipse.sisu.bean.BeanPropertySetter.set(BeanPropertySetter.java:78)
at org.eclipse.sisu.plexus.ProvidedPropertyBinding.injectProperty(ProvidedPropertyBinding.java:48)
at org.eclipse.sisu.bean.BeanInjector.injectMembers(BeanInjector.java:52)
at com.google.inject.internal.MembersInjectorImpl.injectMembers(MembersInjectorImpl.java:160)
at com.google.inject.internal.ConstructorInjector.provision(ConstructorInjector.java:124)
at com.google.inject.internal.ConstructorInjector.access$000(ConstructorInjector.java:32)
at com.google.inject.internal.ConstructorInjector$1.call(ConstructorInjector.java:98)
at com.google.inject.internal.ProvisionListenerStackCallback$Provision.provision(ProvisionListenerStackCallback.java:112)
at com.google.inject.internal.ProvisionListenerStackCallback$Provision.provision(ProvisionListenerStackCallback.java:127)
at com.google.inject.internal.ProvisionListenerStackCallback.provision(ProvisionListenerStackCallback.java:66)
at com.google.inject.internal.ConstructorInjector.construct(ConstructorInjector.java:93)
at com.google.inject.internal.ConstructorBindingImpl$Factory.get(ConstructorBindingImpl.java:306)
at com.google.inject.internal.ProviderToInternalFactoryAdapter.get(ProviderToInternalFactoryAdapter.java:40)
at com.google.inject.internal.SingletonScope$1.get(SingletonScope.java:148)
at com.google.inject.internal.InternalFactoryToProviderAdapter.get(InternalFactoryToProviderAdapter.java:39)
at com.google.inject.internal.FactoryProxy.get(FactoryProxy.java:62)
at com.google.inject.internal.InjectorImpl$1.get(InjectorImpl.java:1050)
at org.eclipse.sisu.wire.BeanProviders.firstOf(BeanProviders.java:179)
at org.eclipse.sisu.wire.BeanProviders$7.get(BeanProviders.java:160)
at com.google.inject.internal.ProviderInternalFactory.provision(ProviderInternalFactory.java:85)
at com.google.inject.internal.InternalFactoryToInitializableAdapter.provision(InternalFactoryToInitializableAdapter.java:57)
at com.google.inject.internal.ProviderInternalFactory$1.call(ProviderInternalFactory.java:66)
at com.google.inject.internal.ProviderInternalFactory.circularGet(ProviderInternalFactory.java:61)
at com.google.inject.internal.InternalFactoryToInitializableAdapter.get(InternalFactoryToInitializableAdapter.java:47)
at com.google.inject.internal.SingleParameterInjector.inject(SingleParameterInjector.java:42)
at com.google.inject.internal.SingleParameterInjector.getAll(SingleParameterInjector.java:65)
at com.google.inject.internal.ConstructorInjector.provision(ConstructorInjector.java:113)
at org.eclipse.sisu.inject.Guice4$1.get(Guice4.java:162)
at org.eclipse.sisu.plexus.PlexusRequirements$RequirementProvider.get(PlexusRequirements.java:250)
at com.google.inject.internal.InjectorImpl.getInstance(InjectorImpl.java:1086)
at org.eclipse.sisu.space.AbstractDeferredClass.get(AbstractDeferredClass.java:48)
at org.eclipse.sisu.bean.BeanScheduler$CycleActivator.onProvision(BeanScheduler.java:230)
at com.google.inject.internal.ProvisionListenerStackCallback$Provision.provision(ProvisionListenerStackCallback.java:120)
... 23 more
Previous Topic:Sisu repositories have moved to GitHub
Next Topic:Forum moved to GitHub Discussions
Current Time: Fri Sep 26 19:11:22 EDT 2025
Powered by FUDForum. Page generated in 0.02619 seconds
