eclipse installer does not start on OpenSuse Leap 15.4 [message #1854536] |
Wed, 24 August 2022 09:44 |
Franz Gotsis Messages: 1 Registered: August 2022 |
Since updating to OpenSuse Leap 15.4 (running KDE-Plasma 5 as environment)
I do have the issue that I cannot start the eclipse-installer (running KDE Plasma as shell). Existing eclipse installations still do work, although they have numerous problems (starting the market place will crash eclipse as well as subversion plugin subclipse stopped working. Pressing CTRL+Space opens up a context view but immediately after opening the window eclipse will stop with the same strace content.
I tried to run with several jdk version that all result in the same error:
OpenJDK 11
OpenJDK 17
Oracle JDK 17
GraalVM on Java Jdk11
It is also reproducible on several different computers as long as OpenSuse LEap 15.4 is used as the operating system.
Debug and logging does not result in anything meaningful, so I tried to run it with strace. The critical lines at the end are:
--- SIGCHLD {si_signo=SIGCHLD, si_code=CLD_EXITED, si_pid=9799, si_uid=1000, si_status=0, si_utime=0, si_stime=0} ---
clone(child_stack=NULL, flags=CLONE_CHILD_CLEARTID|CLONE_CHILD_SETTID|SIGCHLD, child_tidptr=0x7f01fe8d2e50) = 9819
wait4(9819, SLF4J: Failed to load class "org.slf4j.impl.StaticLoggerBinder".
SLF4J: Defaulting to no-operation (NOP) logger implementation
SLF4J: See <snip> for further details.
[{WIFSIGNALED(s) && WTERMSIG(s) == SIGABRT && WCOREDUMP(s)}], 0, NULL) = 9819
--- SIGCHLD {si_signo=SIGCHLD, si_code=CLD_KILLED, si_pid=9819, si_uid=1000, si_status=SIGABRT, si_utime=882, si_stime=33} ---
shmctl(294972, IPC_RMID, NULL) = 0
munmap(0x7f01fda53000, 2166888) = 0
getpid() = 9796
getpid() = 9796
exit_group(0) = ?
+++ exited with 0 +++
I have attached the full strace readout.
FUDForum. Page generated in 0.08591 seconds
