Home » Eclipse Projects » Eclipse Platform » How to access getViewer().doOperation(TextViewer.PREFIX) an TextEditor?
How to access getViewer().doOperation(TextViewer.PREFIX) an TextEditor? [message #1853950] Mon, 25 July 2022 13:10 Go to next message
Rubén Porras Campo is currently offline Rubén Porras CampoFriend
Member
I would like to rewrite functionality for a particural org.eclipse.core.commands.AbstractHandler which was coded with an own editor in mind. I would like that it works as well with the ExtensionBasedTextEditor.
The previous custom editor made the method getSourceViewer public an then the implementation of the handler was just
		final TextEditor activeEditor = getActiveEditor().get();
		final ISelection sourceSelection = activeEditor.getSelectionProvider().getSelection();
		if (sourceSelection instanceof ITextSelection) {
			if (isSelectionCommented((ITextSelection) sourceSelection)) {
				activeEditor.getSourceViewer().doOperation(TextViewer.STRIP_PREFIX);
			} else {
				activeEditor.getSourceViewer().doOperation(TextViewer.PREFIX);
since the getSourceViewer() is protected in the AbstractTextEditor and TextEditor does not make it public, I cannot do this call for a generic TextEditor. I get the error The method getSourceViewer() from the type AbstractTextEditor is not visible.
Any ideas how can I reimplement my logic for a TextEditor?
Re: How to access getViewer().doOperation(TextViewer.PREFIX) an TextEditor? [message #1853951 is a reply to message #1853950] Mon, 25 July 2022 13:18 Go to previous message
Member
If it helps, this is the class I want to write
	/** The prefixes. */
	private Map<String, String[]> prefixesMap = null;
	 * Check if ALL of the lines in the given <code>selection</code> are commented.
	 * @param selection
	 *            the <code>ITextSelection</code> to check
	 * @return true if all lines in the given <code>selection</code> are commented, else false
	 * @throws IllegalStateException
	 *             if the line number is invalid
	private boolean isSelectionCommented(final ITextSelection selection) throws IllegalStateException {
		final int startLine = selection.getStartLine();
		final int endLine = selection.getEndLine();
		for (int i = startLine; i <= endLine; i++) {
			try {
				final IDocument document = getActiveEditor().get().getDocumentProvider().getDocument(null);
				final IRegion region = document.getLineInformation(i);
				String line = document.get(region.getOffset(), region.getLength());
				line = StringUtils.stripToEmpty(line);
				final Collection<String[]> c = prefixesMap.values();
				boolean isComment = false;
				for (final String[] a : c) {
					for (final String s : a) {
						if (line.startsWith(s)) {
							// line i is commented
							isComment = true;
				if (!isComment) {
					return false;
			} catch (final BadLocationException e) {
				throw new IllegalStateException(e);
		return true;
	 * Evaluate the prefixes used for commenting a line and store it in this {@link #prefixesMap}.
	private void setPrefixMap() {
		if (prefixesMap != null) {
			return;
		final String[] types = activeEditor.getSourceViewerConfiguration().getConfiguredContentTypes(
				activeEditor.getSourceViewer());
		final Map<String, String[]> pMap = new HashMap<>(types.length);
		for (final String type : types) {
			String[] prefixes = activeEditor.getSourceViewerConfiguration().getDefaultPrefixes(
					activeEditor.getSourceViewer(), type);
			if (prefixes != null && prefixes.length > 0) {
				int emptyPrefixes = 0;
				for (final String prefixe : prefixes) {
					if (prefixe.length() == 0) {
						emptyPrefixes++;
				if (emptyPrefixes > 0) {
					final String[] nonemptyPrefixes = new String[prefixes.length - emptyPrefixes];
					for (int j = 0, k = 0; j < prefixes.length; j++) {
						final String prefix = prefixes[j];
						if (prefix.length() != 0) {
							nonemptyPrefixes[k] = prefix;
							k++;
					prefixes = nonemptyPrefixes;
				pMap.put(type, prefixes);
		prefixesMap = pMap;
	/** {@inheritDoc} */
	protected void execute(final ISelection selection) throws ExecutionException {
		// evaluate the prefixes used for comments
		setPrefixMap();
			} else {
My problem is that getSourceViewer() and getSourceViewerConfiguration() are protected.
Previous Topic:Need help pushing a bug fix to Gerrit
Next Topic:Can't recover offscreen windows
Current Time: Fri Sep 22 13:08:25 GMT 2023
Powered by FUDForum. Page generated in 0.02545 seconds
