Home » Eclipse Projects » Eclipse Scout » Error building scout application(Could not find artifact org.eclipse.platform:org.eclipse.osgi:jar:3.18.100-SNAPSHOT)
Error building scout application [message #1853833] Tue, 19 July 2022 07:57 Go to next message
Error when building scout application.
Error:  Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:3.10.1:compile (default-compile) on project kayloo.invoice.shared: Execution default-compile of goal org.apache.maven.plugins:maven-compiler-plugin:3.10.1:compile failed: Plugin org.apache.maven.plugins:maven-compiler-plugin:3.10.1 or one of its dependencies could not be resolved: Could not find artifact org.eclipse.platform:org.eclipse.osgi:jar:3.18.100-SNAPSHOT in eclipse.snapshot (https://repo.eclipse.org/content/groups/snapshots/) -> [Help 1]
I know that the error is not scout related. May be someone building a scout application the last days has encountered similar errors.
Re: Error building scout application [message #1853834 is a reply to message #1853833] Tue, 19 July 2022 07:59 Go to previous messageGo to next message
Take a look at https://www.eclipse.org/forums/index.php/t/1111180/ - this thread may solve your problem.
Re: Error building scout application [message #1853839 is a reply to message #1853834] Tue, 19 July 2022 08:55 Go to previous message
The indicated thread solved my problem.
Thank you for your quick answer.
Previous Topic:Core Exception in pom.xml files
Next Topic:Add JAR library to Scout project without Maven
Current Time: Mon Sep 22 01:04:02 EDT 2025
Powered by FUDForum. Page generated in 0.02869 seconds
