XTEXT Scoping Issue [message #1853496] |
Tue, 05 July 2022 13:49 |
Marc Kaiser Messages: 16 Registered: July 2022 |
Example of Grammar that doesnt Work:
grammar org.xtext.EcuCValues_Extend with org.eclipse.xtext.common.Terminals
generate ecuCValues_Extend "http://www.xtext.org/EcuCValues_Extend"
Model:
(lines+=Line)*
Line:
(rule = Rule)
Rule:
("ForEach" anchor=AnchorValue);
AnchorValue:
(ARClass = TAG_NO_DOT ".class") | (arpath=AbsoluteARPathContainer);
AbsoluteARPathContainer:
"/" path = ARPathContainer_With_Relative
ARPathContainer_With_Relative:
path+=(ARPathElement)+;
ARPathElement:
//(move=TAG_NO_DOT_RULE | move_rel=RELATIVE_MOVEMENT) "/"
(move=[TAG_NO_DOT_FUNC] | move_rel=RELATIVE_MOVEMENT) "/"
TAG_NO_DOT_FUNC:
name = TAG_NO_DOT
QualifiedName:
TAG_NO_DOT
enum RELATIVE_MOVEMENT:
ONEBACK=".." | HERE=".";
terminal TAG_NO_DOT:
('a'..'z' | 'A'..'Z' | '_' | '0'..'9')+
Example of Grammar that does work:
Model:
(lines+=Line)*
Line:
(rule = Rule)
Rule:
AnchorValue:
ARPathElement:
(move=TAG_NO_DOT_FUNC | move_rel=RELATIVE_MOVEMENT) "/"
TAG_NO_DOT_FUNC:
name = TAG_NO_DOT
QualifiedName:
TAG_NO_DOT
Line of Syntax I want it to parse:
ForEach /Com/ComConfig/ComSignalGroup/
for the XTEXT that doesnt work I get:
required (...)+ loop did not match anything at input
The only difference between the two XTEXT files is the introduction of Scoping. Why does the Scoping break my Grammar? I dont understand and its hard to google for the solution.
[Updated on: Wed, 06 July 2022 09:00] Report message to a moderator
Re: XTEXT Scoping Issue [message #1853520 is a reply to message #1853518] |
Wed, 06 July 2022 12:50 |
Thank you for your useful input Christian. You have found the spot where my Understanding of XTEXT is lacking.
I thought the declaration of TAG_NO_DOT_FUNC is:
TAG_NO_DOT_FUNC:
name = TAG_NO_DOT
apparently for you this is just a reference.
> xtext can only resolved things that have a name.
As you can see TAG_NO_DOT_FUNC does have an element called name. So why can it not be resolved by default?
> TAG_NO_DOT_FUNC is uncalled
What does uncalled mean? How can I call it?
[Updated on: Wed, 06 July 2022 13:20] Report message to a moderator
Re: XTEXT Scoping Issue [message #1853542 is a reply to message #1853538] |
Thu, 07 July 2022 12:03 |
in this grammar TAG_NO_DOT_FUNC is still uncalled
=> you miss the definitions+=Definition* from my grammar.
also the scope_ methods only work if your scope provider inherits from AbstractDeclarativeScopeProvider
by default you need to override getScope(EObject,EReference)
the Comd does not match ID (from QualifiedName), it matches TAG_NO_DOT
Twitter : @chrdietrich
[Updated on: Thu, 07 July 2022 12:03] Report message to a moderator
Re: XTEXT Scoping Issue [message #1853552 is a reply to message #1853549] |
Thu, 07 July 2022 14:53 |
I did add this entry to my Model:
Model:
(stuff+=TAG_NO_DOT_FUNC)*
(lines+=Line)*
Line:
(rule = Rule)
Rule:
AnchorValue:
ARPathElement:
(name=[TAG_NO_DOT_FUNC|QualifiedName] | move_rel=RELATIVE_MOVEMENT) "/"
TAG_NO_DOT_FUNC:
name = ID
QualifiedName:
ID('.' ID)*
I still get "required (...)+ loop did not match anything at input 'Com'".
for
ForEach /Com/CanTpConfig/CanTpChannel/CanTpTxNSdu/
[Updated on: Thu, 07 July 2022 15:04] Report message to a moderator
Re: XTEXT Scoping Issue [message #1853609 is a reply to message #1853568] |
Mon, 11 July 2022 07:41 |
Hello Christian,
I am not progressing much with my issue. I am reading a lot about Scoping in XTEXT in parallel to better understand. It seems to be the most difficult aspect of XTEXT and my knowledge is still too fuzzy.
Could you please help me once more?
Here is my Grammar:
Model:
(tagnodots+=TAG_NO_DOT_FUNC)*
(lines+=Line)*
Line:
(rule = Rule)
Rule:
AnchorValue:
name=(ARPathElement);
ARPathElement:
name=[TAG_NO_DOT_FUNC|QualifiedName] "/"
TAG_NO_DOT_FUNC:
name = ID
QualifiedName:
ID('.'ID)*
I tried to follow your advice so far but its not helping. For Model:
ForEach /CanTpdsConfig/CanTpChannel/CanTpTxNSdu/
I get the Error:
Couldn't resolve reference to TAG_NO_DOT_FUNC 'canTpdsConfig'.
I am trying to Debug the Parser Code. I can see where it goes wrong but I can not understand what goes wrong because the Parser code is not that "human readable".
I can see that he gets a eRecognitionException in function:
// InternalEcuCValues_Extend.g:422:1: ruleQualifiedName returns [AntlrDatatypeRuleToken current=new AntlrDatatypeRuleToken()] : (this_ID_0= RULE_ID (kw= '.' this_ID_2= RULE_ID )* ) ;
public final AntlrDatatypeRuleToken ruleQualifiedName() throws RecognitionException {
AntlrDatatypeRuleToken current = new AntlrDatatypeRuleToken();
Token this_ID_0=null;
Token kw=null;
Token this_ID_2=null;
enterRule();
try {
// InternalEcuCValues_Extend.g:428:2: ( (this_ID_0= RULE_ID (kw= '.' this_ID_2= RULE_ID )* ) )
// InternalEcuCValues_Extend.g:429:2: (this_ID_0= RULE_ID (kw= '.' this_ID_2= RULE_ID )* )
// InternalEcuCValues_Extend.g:430:3: this_ID_0= RULE_ID (kw= '.' this_ID_2= RULE_ID )*
this_ID_0=(Token)match(input,RULE_ID,FOLLOW_9);
current.merge(this_ID_0);
newLeafNode(this_ID_0, grammarAccess.getQualifiedNameAccess().getIDTerminalRuleCall_0());
// InternalEcuCValues_Extend.g:437:3: (kw= '.' this_ID_2= RULE_ID )*
loop4:
do {
int alt4=2;
int LA4_0 = input.LA(1);
if ( (LA4_0==15) ) {
alt4=1;
switch (alt4) {
case 1 :
// InternalEcuCValues_Extend.g:438:4: kw= '.' this_ID_2= RULE_ID
kw=(Token)match(input,15,FOLLOW_7);
current.merge(kw);
newLeafNode(kw, grammarAccess.getQualifiedNameAccess().getFullStopKeyword_1_0());
this_ID_2=(Token)match(input,RULE_ID,FOLLOW_9);
current.merge(this_ID_2);
newLeafNode(this_ID_2, grammarAccess.getQualifiedNameAccess().getIDTerminalRuleCall_1_1());
break;
default :
break loop4;
} while (true);
leaveRule();
catch (RecognitionException re) {
recover(input,re);
appendSkippedTokens();
finally {
return current;
// $ANTLR end "ruleQualifiedName"
in line: this_ID_0=(Token)match(input,RULE_ID,FOLLOW_9);
Is my problem in my Code or is it in my grammar? I would prefer to fix it in the grammar as there is less room for error here..
Re: XTEXT Scoping Issue [message #1853610 is a reply to message #1853609] |
Mon, 11 July 2022 07:51 |
where do you have canTpdsConfig defined
your snippet shows only the use, not the define
// define it
CanTpdsConfig
// use it
i also dont understand why you always switch between parsing problems and scoping problems.
which one are we looking at now
also again
and the ID conflict
and the lexer is context free
so you have to either drop TAG_NO_DOT and use ID everywhere
or dont use ID at all
Re: XTEXT Scoping Issue [message #1853616 is a reply to message #1853610] |
Mon, 11 July 2022 13:45 |
Hi Christian, thank you for your patience with me.
I do not want it to be defined. My goal is for my my getscope implementation to fetch me a list of entries for my context menu for ctrl+space. This I have already successfully implemented. My Problem is that the result that is fetched is not recognized as valid by the Xtext parser. The Canditates that I provide in my IScope shall not be defined previously!
I have replaced ID with TAG_NO_DOT everywhere.
Model:
(lines+=Line)*
Line:
(rule = Rule)
Rule:
AnchorValue:
ARPathElement:
TAG_NO_DOT_FUNC:
name = TAG_NO_DOT
QualifiedName:
TAG_NO_DOT('.'TAG_NO_DOT)*
This doesn't change the Error I am getting from the Editor:
Couldn't resolve reference to TAG_NO_DOT_FUNC 'cdsanTpdsConfig'.
How can I tell my grammar to accept the Strings that my IScope fetches?
[Updated on: Mon, 11 July 2022 13:49] Report message to a moderator
Re: XTEXT Scoping Issue [message #1853622 is a reply to message #1853616] |
Mon, 11 July 2022 17:14 |
As I Said. Cannot resolve reference is a scoping problem not a parse problem If you have a reference
Xxxx=[Yyyyyy] then the Yyyyyy needs to be declared somewhere else
If you just want to do content assist and not declare really reference something
Can you give some details what you do in scoping
Re: XTEXT Scoping Issue [message #1853640 is a reply to message #1853636] |
Tue, 12 July 2022 07:40 |
you cannot. but if you want to have references into autosar. then you need to load a reference into autosar resources into scoping.
e.g. the ecucvalues dsl part of artop does that.
so the question again would be: what did you do in scoping?
did you debug DefaultLinkingServices why scoping fails?
Re: XTEXT Scoping Issue [message #1853645 is a reply to message #1853640] |
Tue, 12 July 2022 09:47 |
did you mean that I need to load the AUTOSAR resources into my scoping? I did load the AUTOSAR objects into my IScope. I created a wrapper class Scope_Object for loading the AR Objects into my IScope. I looks like this:
* Copyright (c) Robert Bosch GmbH. All rights reserved.
package org.xtext.scoping;
import java.lang.reflect.InvocationTargetException;
import org.eclipse.emf.common.notify.Adapter;
import org.eclipse.emf.common.notify.Notification;
import org.eclipse.emf.common.util.EList;
import org.eclipse.emf.common.util.TreeIterator;
import org.eclipse.emf.common.util.URI;
import org.eclipse.emf.ecore.EClass;
import org.eclipse.emf.ecore.EObject;
import org.eclipse.emf.ecore.EOperation;
import org.eclipse.emf.ecore.EReference;
import org.eclipse.emf.ecore.EStructuralFeature;
import org.eclipse.emf.ecore.resource.Resource;
import org.eclipse.emf.ecore.util.EcoreUtil;
import org.eclipse.xtext.naming.QualifiedName;
import org.eclipse.xtext.resource.IEObjectDescription;
* @author AMK2ABT
public class Scope_Object implements EObject, IEObjectDescription {
public QualifiedName QualifiedName;
public Object obj;
public Scope_Object(final String name, final EObject eo) {
setName(name);
setObject(eo);
* {@inheritDoc}
public EList<Adapter> eAdapters() {
EObject eo = (EObject) this.obj;
return eo.eAdapters();
* {@inheritDoc}
public boolean eDeliver() {
return eo.eDeliver();
* {@inheritDoc}
public void eSetDeliver(final boolean deliver) {
eo.eSetDeliver(deliver);
* {@inheritDoc}
public void eNotify(final Notification notification) {
eo.eNotify(notification);
public void setName(final String name) {
this.QualifiedName = org.eclipse.xtext.naming.QualifiedName.create(name);
return;
* {@inheritDoc}
public void setQualifiedName(final String name) {
return;
public void setObject(final EObject eo) {
this.obj = eo;
public Object getObject() {
return this.obj;
* {@inheritDoc}
public QualifiedName getName() {
return this.QualifiedName;
* {@inheritDoc}
public QualifiedName getQualifiedName() {
* {@inheritDoc}
public EObject getEObjectOrProxy() {
return (EObject) this.obj;
* {@inheritDoc}
public URI getEObjectURI() {
return EcoreUtil.getURI(eo);
* {@inheritDoc}
public EClass getEClass() {
EClass ec = eo.eClass();
return ec;
* {@inheritDoc}
public String getUserData(final String key) {
String str = "";
for (String string : this.QualifiedName.getSegments()) {
str += string;
return str;
* {@inheritDoc}
public String[] getUserDataKeys() {
String[] str_arr = (String[]) this.QualifiedName.getSegments().toArray();
return str_arr;
* {@inheritDoc}
public EClass eClass() {
return ec;
* {@inheritDoc}
public Resource eResource() {
Resource er = eo.eResource();
return er;
* {@inheritDoc}
public EObject eContainer() {
EObject ec = eo.eContainer();
return ec;
* {@inheritDoc}
public EStructuralFeature eContainingFeature() {
EStructuralFeature esf = eo.eContainingFeature();
return esf;
* {@inheritDoc}
public EReference eContainmentFeature() {
EReference er = eo.eContainmentFeature();
return er;
* {@inheritDoc}
public EList<EObject> eContents() {
EList<EObject> eo_lst = eo.eContents();
return eo_lst;
* {@inheritDoc}
public TreeIterator<EObject> eAllContents() {
return null;
* {@inheritDoc}
public boolean eIsProxy() {
return eo.eIsProxy();
* {@inheritDoc}
public EList<EObject> eCrossReferences() {
return eo.eCrossReferences();
* {@inheritDoc}
public Object eGet(final EStructuralFeature feature) {
return eo.eGet(feature);
* {@inheritDoc}
public Object eGet(final EStructuralFeature feature, final boolean resolve) {
return eo.eGet(feature, resolve);
* {@inheritDoc}
public void eSet(final EStructuralFeature feature, final Object newValue) {
eo.eSet(feature, newValue);
return;
* {@inheritDoc}
public boolean eIsSet(final EStructuralFeature feature) {
boolean eIsSet = eo.eIsSet(feature);
return eIsSet;
* {@inheritDoc}
public void eUnset(final EStructuralFeature feature) {
eo.eUnset(feature);
* {@inheritDoc}
public Object eInvoke(final EOperation operation, final EList<?> arguments) throws InvocationTargetException {
return eo.eInvoke(operation, arguments);
Then I have written a custom Scope Provider that extends the AbstractDeclarativeScopeProvider:
* generated by Xtext 2.20.0
import java.util.ArrayList;
import java.util.List;
import org.eclipse.emf.common.util.BasicEList;
import org.eclipse.xtext.naming.DefaultDeclarativeQualifiedNameProvider;
import org.eclipse.xtext.scoping.IScope;
import org.eclipse.xtext.scoping.Scopes;
import org.eclipse.xtext.scoping.impl.AbstractDeclarativeScopeProvider;
import org.xtext.ecuCValues_Extend.ARPathContainer_With_Relative;
import org.xtext.ecuCValues_Extend.ARPathElement;
import org.xtext.ecuCValues_Extend.AbsoluteARPathContainer;
import com.bosch.bct.javaaction.modelaccess.artop.IASWModel;
import autosar40.ecucdescription.EcucModuleConfigurationValues;
* This class contains custom scoping description. See
* https://www.eclipse.org/Xtext/documentation/303_runtime_concepts.html#scoping on how and when to use it.
public class EcuCValues_ExtendScopeProvider extends AbstractDeclarativeScopeProvider {
public IScope getScope(final EObject context, final EReference reference) {
EcuCValues_ExtendIndex index = new EcuCValues_ExtendIndex();
List<ARPathElement> candidates = new ArrayList<>();
String projectName = null;
// Get the project name from the EObject
projectName = context.eContainer().eResource().getURI().segment(1);
List<Scope_Object> scope_obj_lst = new BasicEList<>();
IScope scopeFor = null;
// Load the Artop project context and if needed the central elements from CEL
if (projectName != null) {
IASWModel artopModelSingleton = ArtopModelSingleton.getArtopModelSingleton(projectName);
if (context instanceof AbsoluteARPathContainer) {
AbsoluteARPathContainer arpc = (AbsoluteARPathContainer) context;
EObject eContainer = context.eContainer();
ARPathContainer_With_Relative path = arpc.getPath();
// IResourceDescription resourceDescription_1 = index.getResourceDescription(arpc);
// Iterable<IEObjectDescription> exportedEObjectDescriptions_1 = index.getExportedEObjectDescriptions(arpc);
if (path != null) {
ARPathElement full_path = path.getName();
List<EcucModuleConfigurationValues> ecuCValueModules =
artopModelSingleton.getElements(EcucModuleConfigurationValues.class);
for (EcucModuleConfigurationValues values : ecuCValueModules) {
Scope_Object scope_obj = new Scope_Object(values.getDefinition().getShortName(), values);
scope_obj_lst.add(scope_obj);
EObject rootElement = EcoreUtil.getRootContainer(context);
DefaultDeclarativeQualifiedNameProvider qnp = new Scoping_Object_QualifiedName_Provider();
scopeFor = Scopes.scopeFor(scope_obj_lst, qnp, IScope.NULLSCOPE);
if (context instanceof ARPathElement) {
ARPathElement arpe = (ARPathElement) context;
else {
List<EcucModuleConfigurationValues> ecuCValueModules2 =
return scopeFor;
This getScope works in the sense that it is executed and that it is providing me with my context menu entries.
I did not but will seek to do so now.
