Home » Eclipse Projects » Mosquitto » Mosquitto broker "starting in local only mode"(Mosquitto configuration)
Mosquitto broker "starting in local only mode" [message #1853478] Mon, 04 July 2022 09:29
Hey, I am currently trying to configure my Mosquitto broker running headless on a raspberry pi 4...
When running mosquitto -v I always get as response, that its running on local mode only.
1656875923: mosquitto version 2.0.11 starting
1656875923: Using default config.
1656875923: Starting in local only mode. Connections will only be possible from clients running on this machine.
1656875923: Create a configuration file which defines a listener to allow remote access.
1656875923: For more details see ht tps://mosquitto.org/documentation/authentication-methods/
1656875923: Opening ipv4 listen socket on port 1883.
1656875923: Opening ipv6 listen socket on port 1883.
1656875923: mosquitto version 2.0.11 running
The linked docs doesnt help, I already tried bind_address 0.0.0.0 in the mosquitto.conf file, even when allow_anonymous is true it doesnt work.
This is my config file:
  GNU nano 5.4              /etc/mosquitto/mosquitto.conf
# Place your local configuration in /etc/mosquitto/conf.d/
# A full description of the configuration file is at
# /usr/share/doc/mosquitto/examples/mosquitto.conf.example
per_listener_settings true
pid_file /run/mosquitto/mosquitto.pid
persistence true
persistence_location /var/lib/mosquitto/
log_dest file /var/log/mosquitto/mosquitto.log
include_dir /etc/mosquitto/conf.d
allow_anonymous false
listener 1883
password_file /etc/mosquitto/passwd
It works communicating on the machine, but I cant connect with my mqtt dashboard or else.
Could you please help me? Idk what to do anymore, the docs dont really help...
Thanks!
Previous Topic:How to use mosquitto with MS Visual Studio
Next Topic:Mosquitto not allowing external connections
Current Time: Thu Nov 06 16:57:55 EST 2025
Powered by FUDForum. Page generated in 0.03559 seconds
