Home » Eclipse Projects » EGit / JGit » How to get User info from personal access token(How to get User info from personal access token)
How to get User info from personal access token [message #1853182] Wed, 22 June 2022 03:06 Go to next message
Hi Team,
Is there any API which gives user info of gitlab/github by passing access token ?
Mounika.
Re: How to get User info from personal access token [message #1853185 is a reply to message #1853182] Wed, 22 June 2022 03:51 Go to previous messageGo to next message
Please don't cross-post: https://www.eclipse.org/forums/index.php/t/1111027/
It's unclear what you are asking about. An API where? If you're looking for a GitHub/Gitlab API, check their API documentation.
Re: How to get User info from personal access token [message #1853214 is a reply to message #1853185] Thu, 23 June 2022 05:07 Go to previous messageGo to next message
We have personal access token from github/gitlab, with that token we are able to perform actions like clone,commit,push,pull etc using JGIT.
We would like to access personal information like user id, email id for that personal access token. What is the api we need to use for getting this?
Re: How to get User info from personal access token [message #1853216 is a reply to message #1853214] Thu, 23 June 2022 05:42 Go to previous messageGo to next message
I think you are asking for something that's not possible and kind of nonsensical. The personal access token is like a password and your question is like asking "Given a github password, I'd like to find out for which account is that the password?"
Perhaps do some Googling and reading will help, e.g.,
https://www.edgoad.com/2021/02/using-personal-access-tokens-with-git-and-github.html
You must know the user ID to do anything with the PAT. Or are you asking how to find user.id/user.email information in the git config? That question has nothing to do with there being a PAT or not...
Re: How to get User info from personal access token [message #1853228 is a reply to message #1853214] Thu, 23 June 2022 09:07 Go to previous messageGo to next message
Hey, I think you actually want to generate an ssh key and add it to github. That will allow you to interact with github from your command line with no further configuration.
There is a pretty good guide here https://docs.github.com/en/authentication/connecting-to-github-with-ssh/adding-a-new-ssh-key-to-your-github-account
You might get a little flack from this community as its not affiliated with GitHub, but rather an implementation of the program git in java.
Good luck!
Re: How to get User info from personal access token [message #1853256 is a reply to message #1853228] Fri, 24 June 2022 06:45 Go to previous messageGo to next message
Basically, I want to know user name and user email from git.
I have seen PersonIdent class by passing repo as input. But it is not giving me actual user name and email id.
Could you please help me
[Updated on: Fri, 24 June 2022 06:47] by Moderator
Re: How to get User info from personal access token [message #1853262 is a reply to message #1853256] Fri, 24 June 2022 08:55 Go to previous message
Now this sounds like a duplicate of https://www.eclipse.org/forums/index.php/t/1111060/ . See there.
Previous Topic:Does JGIT allow for running commands in parallel?
Next Topic:Retrieve User Name and Email Address from the Git Repo
Current Time: Sun Jul 27 18:36:38 EDT 2025
Powered by FUDForum. Page generated in 0.04631 seconds
