Home » Newcomers » Newcomers » What flavor of regex flavor is used by latest Eclipse IDE?
What flavor of regex flavor is used by latest Eclipse IDE? [message #1852826] Mon, 06 June 2022 14:53 Go to next message
I am talking about "Find/Replace" dialog (Ctrl+F).
It seems to support "variable length lookbehind" regex which doesn't seem to be supported in Java. Or, is it really using Java?
I need to know exact version if possible.
Re: What flavor of regex flavor is used by latest Eclipse IDE? [message #1852828 is a reply to message #1852826] Tue, 07 June 2022 01:23 Go to previous message
Search uses this which definitely creates a java.util.regex.Pattern.
org.eclipse.search.internal.core.text.PatternConstructor.createPattern(String, boolean, boolean, boolean, boolean)
Also in org.eclipse.jface.text.FindReplaceDocumentAdapter.findReplace(FindReplaceOperationCode, int, String, String, boolean, boolean, boolean, boolean) is does a Pattern.compile so it is just using what's provided by the JDK.
Previous Topic:Need help
Next Topic:Error opening file for writing issue
Current Time: Tue Oct 28 18:02:55 EDT 2025
Powered by FUDForum. Page generated in 0.08289 seconds
