EMF diff Merge usage on this folder? [message #1852529] |
Fri, 20 May 2022 13:30 |
Namea lasta Messages: 50 Registered: March 2022 |
Member |
I was exploring the contents of an addon (used in an eclipse soft, Capella for instance), which contains the following:
org.eclipse.emf.diffmerge.bridge
org.eclipse.emf.diffmerge.bridge.incremental
org.eclipse.emf.diffmerge.bridge.interactive
org.eclipse.emf.diffmerge.bridge.mapping
org.eclipse.emf.diffmerge.bridge.traces.gen
org.eclipse.emf.diffmerge.bridge.traces.gen.edit
org.eclipse.emf.diffmerge.bridge.traces.gen.editor
org.eclipse.rmf.reqif10
org.eclipse.rmf.reqif10.common
org.eclipse.rmf.reqif10.edit
org.eclipse.rmf.reqif10.serialization
org.eclipse.rmf.reqif10.xhtml
org.eclipse.rmf.reqif10.xhtml.edit
org.eclipse.sphinx.emf.serialization
It also contain lot of plugins.jar from 2 categories:
- org.polarsys.capella.vp.requirements, ........
and
- org.polarsys.kitalpha.vp.requirements. ........
Questions:
-> Do you think the emf merge tool has been used to create this?
-> If yes, is there any wat to "study" the mentioned diffmerge files to try to find out the "story" / "effects" of the merging? And thus, being able to "climb" back to the original metamodels?
I tried "extracting " some useful files to study them individually, but i was not successful, the plugins of one type seems t be intertwined with the other.....
Edit: The merge files are mensioned here (https://github.com/eclipse/capella-requirements-vp)
PS-> The capella forum addon section is sometimes deserted (sometimes). I'd prefer to post here.
[Updated on: Fri, 20 May 2022 13:32] Report message to a moderator
FUDForum. Page generated in 0.03610 seconds
