Home » Eclipse Projects » EGit / JGit » Search all versions of a file with jgit log takes long
Search all versions of a file with jgit log takes long [message #1852251] Fri, 06 May 2022 03:42 Go to next message
Hi.
When I search all versions of a specific file with jGit takes a long time, more that 6 minutes.
My repo has about 40k commits.
However, if I run
 git log --path
in command line, the result is instantaneos.
Here is the code we use:
        Git repo = Git.open(new File(repoPath));
        Iterable<RevCommit> commits = repo.log().addPath(fileName).call();
        Iterator<RevCommit> commit_it = commits.iterator();
        while(commit_it.hasNext()){
            RevCommit commit = commit_it.next();
Any idea how to improve the performance using jGit?
Re: Search all versions of a file with jgit log takes long [message #1852420 is a reply to message #1852251] Sun, 15 May 2022 17:52 Go to previous message
Have a look how
https://git.eclipse.org/r/plugins/gitiles/jgit/jgit/+/refs/heads/master/org.eclipse.jgit/src/org/eclipse/jgit/api/LogCommand.java
uses PathFilters to filter the git log for a path
Previous Topic:Adding JGIT to AEM results in dependency resolving issue
Next Topic:Egit showing all .class file in unstaged changes after building workspace
Current Time: Sun Jun 22 08:40:27 EDT 2025
Powered by FUDForum. Page generated in 0.04425 seconds
