| Instantiating and Populating BP diagrams programmatically [message #1852228] |
Thu, 05 May 2022 08:46  |
Good day everyone,
I have been trying to use BPMN2 MDT eclipse inside another eclipse project. So far, I am able to open and access the elements of an existing BP diagram. However, I'm having quite a hard time figuring out how to create a new BP diagram and populate it with elements programmatically. I saw a similar thread here: https://www.eclipse.org/forums/index.php/m/1775421/?srch=create+elements+programmatically#msg_1775421. However, it seems like what it tries to do is change programmatically the bp diagram that is loaded in the editor. I'm wondering if I can do the changes without having to load the editor (meaning, directly change the bpmn2 file).
In any case, I would also have to load bpmn2 modeler via another eclipse project (I set this aside for the moment since I'm having a validation error whenever I add the org.eclipse.bpmn2.modeler in the project contents).
I hope someone could help.
In any case, thank you in advance, everyone!
FUDForum. Page generated in 0.03641 seconds
