Home » Newcomers » Newcomers » IDE Release Notes(Where can I access IDE release notes)
IDE Release Notes [message #1851891] Thu, 21 April 2022 05:24 Go to next message
Seems like a dumb question, but I cannot find them :-(
I have a project that builds on 2020-06 with Java1.8, but will not build under 2022-03 with Java17, so need to know if there is new configuration needed (for cross-project dependencies).
Re: IDE Release Notes [message #1851944 is a reply to message #1851891] Fri, 22 April 2022 07:38 Go to previous messageGo to next message
I'm not sure if these are helpful:
https://www.eclipse.org/eclipse/news/
Re: IDE Release Notes [message #1851954 is a reply to message #1851944] Fri, 22 April 2022 13:25 Go to previous messageGo to next message
There used to be something here: https://www.eclipse.org/eclipseide/2022-03/noteworthy/ , but apparently there was a web page redesign/restructuring; it is now a redirect to https://eclipseide.org/release/ , and the "New & Noteworthy" button there gives me... nothing.
Re: IDE Release Notes [message #1852001 is a reply to message #1851954] Mon, 25 April 2022 11:37 Go to previous messageGo to next message
Hi Thomas,
I am concerned that the N&N button isn't working for you on the new page. Can you identify why? It should link to https://eclipseide.org/release/noteworthy/
Thanks!
Jonah
Re: IDE Release Notes [message #1852009 is a reply to message #1852001] Mon, 25 April 2022 14:00 Go to previous messageGo to next message
Hi Jonah; it does. But that page gives me only an endlessly spinning "loading" graphics.
I have googletagmanager blocked, and my ad blocker blocks the following three requests on that page: https://clients1.google.com/generate_204 , https://cse.google.com/adsense/search/async-ads.js , and ​https://www.googletagmanager.com/gtm.js?id=GTM-5WLCZXC .
I wonder why that page is loading this image: https://www.google.com/cse/static/images/2x/en/branding.png .
I'm using Firefox 99.0.1 on OS X.
I cannot further identify why that page doesn't show any useful content. Probably some JS bug.
Re: IDE Release Notes [message #1852128 is a reply to message #1852009] Sun, 01 May 2022 09:57 Go to previous messageGo to next message
Thanks Thomas - I have raised https://gitlab.eclipse.org/eclipse-wg/ide-wg/eclipseide.org/-/issues/23 with the webdev team on this issue.
For me the loading symbol spins briefly with Adblock Plus installed (Chrome on Linux) but then the page loads properly
Re: IDE Release Notes [message #1852159 is a reply to message #1852128] Mon, 02 May 2022 19:52 Go to previous messageGo to next message
@Thomas - if you are able to, can you answer the question from Eclipse WebDev team so that we can fix the problem with the new pages? https://gitlab.eclipse.org/eclipse-wg/ide-wg/eclipseide.org/-/issues/23#note_721239 thank you!
Re: IDE Release Notes [message #1852160 is a reply to message #1852159] Tue, 03 May 2022 01:40 Go to previous message
Done. Works now -- the adblocker add-on in my FF installation needed a manual update.
Previous Topic:IDE launhcer only shows the top bar
Next Topic:Checksum for OpenJDK11U-jdk_x64_windows_hotspot_11.0.15_10.msi
Current Time: Mon Sep 01 01:49:36 EDT 2025
Powered by FUDForum. Page generated in 0.33239 seconds
