Re: Alternative to deprecated flowport [message #1851229 is a reply to message #1851209] |
Thu, 31 March 2022 12:00 |
You can read the section C4 of the norm SysML1.6 (p 234):
"To convert a SysML 1.2 flow port to ports in this version of SysML it is recommended to use the following guidelines:
1. Decide if the port should be converted to a proxy port, a full port, or an unstereotyped port.
2. Based on the decision in step 1, create a block (for proxy ports, it shall be an interface block specifically).
3. If the original flow port is non-atomic:
a. Copy all the flow properties owned by the flow port's type, a flow specification, to the block created in step 2 (meaning the flow properties will be owned by the newly created block).
b. Replace the type of the port with the block created in step 2.
c. Remove the flow port stereotype from the port.
d. Based on the decision in step 1, apply the ProxyPort or FullPort stereotype, or do nothing if the decision is not to use either one.
e. If the proxy stereotype is applied in step 3d, and there is a single connector from the port to a part, the BindingConnector may be applied to the connector.
f. If the flow specification is not referenced by other model elements, delete it.
4. If the original flow port is atomic:
a. On the block created in step 2, specify a flow property typed by the same type as the flow port and with the same direction as the original flow port.
b. Do steps b to d from step 3 about non-atomic flow ports."
Patrick
FUDForum. Page generated in 0.03310 seconds
