Home » Newcomers » Newcomers » CVS in Eclipse 2022-03 is missing(CVS in Eclipse 2022-03 is missing)
CVS in Eclipse 2022-03 is missing [message #1851035] Fri, 25 March 2022 06:31 Go to next message
Yesterday I installed Eclipse 2022-03 on my Linux laptop. While installation I tried to add the additional packages I need (EPIC, bash Editor, etc). Trying to activate CVS client I did not succeed.
I think I need some hints how to get it activated. Most of our code is saved to CVS repositories so I need to have this functionality.
Sincerely
Joern
Re: CVS in Eclipse 2022-03 is missing [message #1851046 is a reply to message #1851035] Fri, 25 March 2022 11:31 Go to previous messageGo to next message
Sorry, CVS support was dropped.
https://www.eclipse.org/lists/cross-project-issues-dev/msg18643.html
Re: CVS in Eclipse 2022-03 is missing [message #1851224 is a reply to message #1851046] Thu, 31 March 2022 04:27 Go to previous messageGo to next message
When you rely on this feature, you should be able to install it from a previous release. This might work now, but it is not guaranteed for the future.
You could also build & maintain the feature yourself.
Or just use an older version when interacting with CVS.
Please understand that development resources are limited and have to focus on more widely used features.
Re: CVS in Eclipse 2022-03 is missing [message #1851226 is a reply to message #1851224] Thu, 31 March 2022 04:58 Go to previous messageGo to next message
Or you should consider getting involved or sponsoring someone to get involved on your behalf:
https://github.com/eclipse-platform/eclipse.platform.team/issues/8
The runway has grown short...
Re: CVS in Eclipse 2022-03 is missing [message #1852321 is a reply to message #1851035] Tue, 10 May 2022 10:49 Go to previous messageGo to next message
Same problem here.
CVS plugin works here after in-place upgrade from Eclipse 2021-12 to 2022-03.
Re: CVS in Eclipse 2022-03 is missing [message #1852361 is a reply to message #1851224] Wed, 11 May 2022 13:47 Go to previous messageGo to next message
Or follow the rest of the world and convert your CVS repositories to Git before that support is also dropped... ;)
https://stackoverflow.com/questions/20869710/migrate-from-cvs-to-git-without-losing-history
Re: CVS in Eclipse 2022-03 is missing [message #1853052 is a reply to message #1852361] Wed, 15 June 2022 17:24 Go to previous messageGo to next message
We found that you can install 2022-03 directly and then install the CVS functionality by installing the Eclipse 2021-12 (4.22) support for CVS.
On Eclipse, click on Help -> Install New Software...
On the Available Software dialog, click "Add". On the "Add Repository" box, enter Name: CVS Support; Location: https://download.eclipse.org/eclipse/updates/4.22
Click "Eclipse CVS Client" and install the CVS Client components.
I hope this continues to work. While we would love to migrate to Git, we have a 20 year old CVS repository and a CVS-oriented development process that we just don't have time to stop and migrate.
Re: CVS in Eclipse 2022-03 is missing [message #1853061 is a reply to message #1853052] Thu, 16 June 2022 03:20 Go to previous messageGo to next message
No, it's really gone:
For it to come back someone (i.e, someone like you or your organization) needs to physically do the work to maintain it long term and to include it in the builds long term.
Only a few member companies have joined the Eclipse IDE Working group and CVS support is not a priority for those members either:
https://eclipseide.org/
Re: CVS in Eclipse 2022-03 is missing [message #1858542 is a reply to message #1851035] Thu, 06 April 2023 10:46 Go to previous messageGo to next message
I modified a copy of eclipse.team source repository to build the CVS Client and I made quick fixes for Eclipse 2023
The repository is here https://github.com/JAndrassy/org.eclipse.team.cvs
There are build jars in the Release section to test the plugin as a drop-in. (Only for Eclipse versions starting from 2023-03!)
Re: CVS in Eclipse 2022-03 is missing [message #1859271 is a reply to message #1858542] Thu, 25 May 2023 09:56 Go to previous messageGo to next message
Hi Juraj, wonderful news.
I am going to test your CVS fix for eclipse 2023+ from https://github.com/JAndrassy/org.eclipse.team.cvs
Seems promising. Any warnings ?
Re: CVS in Eclipse 2022-03 is missing [message #1859778 is a reply to message #1858542] Tue, 27 June 2023 01:05 Go to previous messageGo to next message
Hi Juraj, how can I build/install your workaround ?
Re: CVS in Eclipse 2022-03 is missing [message #1860232 is a reply to message #1859778] Mon, 24 July 2023 13:32 Go to previous message
There is an "update site" URL noted in the readme of https://github.com/JAndrassy/org.eclipse.team.cvs, namely, https://storage.googleapis.com/eclipse-cvs-plugin/. You can use that to install it. I found I had to uncheck "Group items by category" and was then able to complete the installation.
My sincerest thanks J. Andrassy migrating to Git has been on our to-do list for a decade now and you have given us just a little more breathing room.
Previous Topic:Error while Building project
Next Topic:"Target is not a JDK root" error
Current Time: Tue Oct 28 20:01:44 EDT 2025
Powered by FUDForum. Page generated in 0.08826 seconds
