| Policy for public access to some attributes [message #1850934] |
Tue, 22 March 2022 14:56  |
We use Eclipse Ditto for telemetry data for different types of vehicles. The vehicles have attributes like VIN, Serial Number, Manufacturer, etc. and features which are updated by the telemetry servers.
Now we have a use case where we want part of the attributes saved in Ditto to be public so anyone with an ID can see these. For example we have an internal ID "dummy-id-123". We have an API like this: "api.dummy-site.com/show-public-data?id=dummy-id-123".
In this case the subject is not authenticated nor authorized, basically anonymous. Normally all our things are saved in Ditto with a policy which defined subject and group so the subject or the group have access to the Thing. We searched the documentation for policies but found no entry exemplifying our use case and a solution.
Any help is welcomed.
| Re: Policy for public access to some attributes [message #1850944 is a reply to message #1850934] |
Wed, 23 March 2022 03:06  |
Hi there.
That is a valid use-case, which however is currently not possible to do with Ditto.
There is (not yet) an "anonymous" subject in a Policy and Ditto's gateway strictly enforces user authentication.
Having said that you should however be able to solve this by using the "pre-authentication" - https://www.eclipse.org/ditto/installation-operating.html#pre-authentication
You could configure your nginx (or other reverse proxy sitting in front of Ditto's HTTP API) to always inject the "x-ditto-pre-authenticated" header, e.g. as:
proxy_set_header x-ditto-pre-authenticated "anonymous:access"
Then you can use this "anonymous" user as if it were a normal subject in your policy, e.g.:
"policyId": "my.namespace:policy-a",
"entries": {
"anon": {
"subjects": {
"anonymous:access": {
"type": "unauthenticated, anonymous users"
"resources": {
"thing:/attributes/public": {
"grant": ["READ"],
"revoke": []
What you mentioned with the "id" as part of your API could also be a "subject" which is injected via the "x-ditto-pre-authenticated" header, e.g.:
proxy_set_header x-ditto-pre-authenticated "via-id:${http_id}"
Does this help you for your usecase?
Best regards
Thomas
[Updated on: Wed, 23 March 2022 03:22] by Moderator
FUDForum. Page generated in 0.05172 seconds
