Home » Language IDEs » AspectJ » Joinpoint for TestNG tests?(Trying to create a joinpoint that picks out TestNG tests)
Joinpoint for TestNG tests? [message #1850831] Thu, 17 March 2022 19:27 Go to next message
Hi - I am trying to define a joinpoint that selects TestNG tests. Here is my example test: (defined under src/test/java)
@Test()
public void testHandlingTestErrorException() {
throw new TestErrorException("Fail test", testCause, FAIL);
Here are various joinpoint definitions I have tried:
void around(): call(public void *.test*()) {
System.out.println("In test method...");
proceed();
void around(): within(org.testng.annotations.Test) {
proceed();
after() throwing (Throwable t): execution(* *.test*()) {
System.out.println("In after() throwing");
However all of them result in "advice defined in TestAspect has not been applied" when I compile. Any ideas what might be wrong here? I have tried with and without "<scope>test</scope>" in pom.xml. Thanks in advance.
Re: Joinpoint for TestNG tests? [message #1861464 is a reply to message #1850831] Fri, 13 October 2023 15:18 Go to previous message
The issue might be related to the way you have defined your pointcuts.
Previous Topic:memory consumption
Next Topic:Aspects to monitor/intercept test code
Current Time: Sun Nov 09 17:47:57 EST 2025
Powered by FUDForum. Page generated in 0.03728 seconds
