Home » Modeling » TMF (Xtext) » From custom types to Java types
From custom types to Java types [message #1850446] Thu, 03 March 2022 04:45 Go to next message
Suppose I want users to be able to write a model like this:
entity Foo {
  amount: Number
  relative: Bar
entity Bar {
That is, features of an entity can have as type either another entity, or some pre-defined type such as 'Text' or 'Number'. I will need to validate that this is true, so that one cannot use some other arbitrary type. I will also need to map these pre-defined types to Java types when generating code, e.g. 'Text' -> 'java.lang.String', and 'Number' -> 'java.math.Bigdecimal'.
How can I express this in a grammar? This is what i got so far:
grammar my.package.Dsl with org.eclipse.xtext.xbase.Xtype
generate dsl "..."
Model:
    (elements+=Entity)*;
Entity:
    'entity' name=ID '{'
        (features+=Feature)*
Feature:
    name=ID ':' type=[FeatureType|QualifiedName];
FeatureType:
	 Entity;
// this is possible in the grammar, although with warning, and I cannot check for the type in validation and code generation:
//FeatureType:
//    Entity | 'Text' | 'Number';
Any help appreciated.
Re: From custom types to Java types [message #1850459 is a reply to message #1850446] Thu, 03 March 2022 10:10 Go to previous messageGo to next message
if you do the xbase route you should check https://www.eclipse.org/Xtext/documentation/104_jvmdomainmodel.html
if not you should have something like
Model:
Entity:
Feature:
    name=ID ':' type=FeatureType;
FeatureType: SimpleType | Ref;
Ref: e=[Entity];
SimpleType: type=('Text' | 'Number');
Re: From custom types to Java types [message #1850460 is a reply to message #1850446] Thu, 03 March 2022 10:11 Go to previous messageGo to next message
Hi Mandy,
I think the best is to avoid having Number and Text as part of the grammar. Instead you can have the types as built-in types by defining them in an xmi file and the accessing the file using custom scoping.
See an example file in https://github.com/dsldevkit/dsl-devkit/blob/master/com.avaloq.tools.ddk.typesystem/model-instance/BuiltInTypeModel.xmi and the code to read the file and create the EObjects in https://github.com/dsldevkit/dsl-devkit/blob/master/com.avaloq.tools.ddk.typesystem/src/com/avaloq/tools/ddk/typesystem/BuiltInTypeModelAccess.java
Re: From custom types to Java types [message #1850473 is a reply to message #1850459] Fri, 04 March 2022 02:32 Go to previous messageGo to next message
Christian Dietrich wrote on Thu, 03 March 2022 15:10
Thanks Christian, I read this tutorial earlier but I am not sure if it helps in my case. The idea of my language is that the person writing a model does not have to know anything about concrete Java types, this is why I want to pre-define just a few "types of types" such as textual or numeric types, also dates etc. Only during generation these shall be mapped to specific Java types like String, Double etc. This way I could also decide to change the types later, e.g. when I find that BigDecimal would be a better fit than Double for the "numeric" types. But the user should not be bothered with this and should not need to worry about imports etc like in the example.
Rubén Porras Campo wrote on Thu, 03 March 2022 15:11
Thanks Rubén, sounds like an interesting idea. I will have a look at it and try to figure out how to use it. Would I need to put it into a separate project and reference it from my xtext project?
Re: From custom types to Java types [message #1850479 is a reply to message #1850473] Fri, 04 March 2022 06:34 Go to previous messageGo to next message
but then the
Ref: e=[Entity];
should work, doesnt it?
Re: From custom types to Java types [message #1850480 is a reply to message #1850479] Fri, 04 March 2022 07:39 Go to previous messageGo to next message
Christian Dietrich wrote on Fri, 04 March 2022 11:34
but then the
Ref: e=[Entity];
Kind of. In this simple example yes. My actual grammar is a bit more complex, I simplified it here for you. Actually I have more than one type of entity and I will need to figure out the correct rules, currently the ANTLR parser generator does not accept my grammar because of ambiguities ("Decision can match input such as "RULE_ID" using multiple alternatives"). But since the simplified example is working, I guess I should get it to work in the real grammar, too.
Re: From custom types to Java types [message #1850484 is a reply to message #1850480] Fri, 04 March 2022 11:03 Go to previous message
if my snippet there in 1 id only
the implicit one e=[Entity]; ==> e=[Entity|ID];
so you must have a second one somewhere else e.g
e=[X] | f=[Y]
Previous Topic:Installation of older SDK Versions broken
Next Topic:Export DSL to PDF along with highlighting
Current Time: Tue May 20 02:01:10 EDT 2025
Powered by FUDForum. Page generated in 0.07959 seconds
