Found but could not load [message #1850037] |
Fri, 11 February 2022 12:22  |
Hi. I installed on Windows 10 Pro and am referencing the JRE at the path below. But as I attempt to reference this path during the install of a program that requires v11 of the JRE, I receive the following error:
Found 'C:\Program Files\Eclipse Adoptium\jdk-11.0.14.101-hotspot\bin\server' but couldn't load it
Uncertain if I have the incorrect path value reflected in my Environment variables? I could use some guidance on reviewing if I have my Windows install of this correct.
Thanks.
I have this user Path variable value set - C:\Program Files\Eclipse Adoptium\jdk-11.0.14.101-hotspot
I have the system Path variable value set and at the top of the list - C:\Program Files\Eclipse Adoptium\jdk-11.0.14.101-hotspot\
And I have the Java Home value set - C:\Program Files\Eclipse Adoptium\jdk-11.0.14.101-hotspot\
FUDForum. Page generated in 0.03349 seconds
