Home » Newcomers » Newcomers » How to write Java 7 code on the latest Eclipse?(Java 7)
How to write Java 7 code on the latest Eclipse? [message #1849824] Thu, 03 February 2022 10:55 Go to next message
"Current releases of Eclipse require Java 11 JRE/JDK or newer. "
Does that mean that I cannot write Java 7 code?
Re: How to write Java 7 code on the latest Eclipse? [message #1849831 is a reply to message #1849824] Thu, 03 February 2022 13:52 Go to previous message
No, it only means exactly what it says, that Eclipse itself requires at least Java 11 to run
it. The version you compile your own code against, and the version you use to run it, can
be 1.7 without issue. That's best done if you actually have a Java 1.7 installed and runnable,
of course.
[Updated on: Thu, 03 February 2022 13:57] by Moderator
Previous Topic:Importing a Gradle Project into Eclipse
Next Topic:Cross Compile Alsa for Windows
Current Time: Fri Nov 07 08:02:36 EST 2025
Powered by FUDForum. Page generated in 0.08515 seconds
