Does RCPTT support Java 11 and Eclipse 4.22? [message #1849361] |
Thu, 13 January 2022 16:00  |
Hi there,
We have been trying run RCPTT with my product which is built with open JDK 11 and Eclipse 4.22.
However, we are running in to various issues with RCPTT. When we tried to add the application to the RCPTT tool, we got an error saying that it cannot find the application.
I also tried creating a runtime-workbench config, and try to test it as an Eclipse application. While I can run this configuration successfully without RCPTT, it gives me errors when we launch it under test.
I got the following errors:
An internal error occurred during: "Launching New_configuration (1)".
org/eclipse/pde/internal/core/PDECore.acquireService(Ljava/lang/String;)Ljava/lang/Object; (loaded from file:/Users/chanskw/eclipse/Eclipse-202212/Eclipse.app/Contents/Eclipse/../../../../../.p2/pool/plugins/org.eclipse.pde.core_3.15.0.v20211020-1251.jar by org.eclipse.osgi.internal.loader.EquinoxClassLoader@81686f5a[org.eclipse.pde.core:3.15.0.v20211020-1251(id=433)]) called from class org.eclipse.rcptt.launching.p2utils.P2Utils (loaded from file:/Users/chanskw/eclipse/Eclipse-202212/Eclipse.app/Contents/Eclipse/../../../../../.p2/pool/plugins/org.eclipse.rcptt.launching.p2utils_2.1.0.201510050740.jar by org.eclipse.osgi.internal.loader.EquinoxClassLoader@d4150e0[org.eclipse.rcptt.launching.p2utils:2.1.0.201510050740(id=507)]).
So, does RCPTT support the latest Eclipse and Open JDK 11?
Thanks!
Samantha
Re: Does RCPTT support Java 11 and Eclipse 4.22? [message #1855175 is a reply to message #1849901] |
Fri, 30 September 2022 05:59  |
Java 11 should not be an issue, we are also using the same jdk in our projects with rcptt. Eclipse 4.22 may be the issue here.
Also remember to have RCPTT IDE also started with the same Java to not have some strange effects.
[Updated on: Fri, 30 September 2022 05:59] by Moderator
FUDForum. Page generated in 0.05881 seconds
