Home » Eclipse Projects » EclipseLink » OpenJDK11 and eclipse link 2.7.1 Compatibility issue - Named query not found
OpenJDK11 and eclipse link 2.7.1 Compatibility issue - Named query not found [message #1849084] Sun, 02 January 2022 23:53 Go to next message
Below jars worked fine with OracleJDK 11 but not with openJDK11.
1. eclipselink.2.7.1.jar
2. javax.persistence.2.1.1.jar
Getting below exception when migrating to openjdk.
java.lang.IllegalArgumentException: NamedQuery of name: abcd not found.
at org.eclipse.persistence.internal.jpa.QueryImpl.getDatabaseQueryInternal(QueryImpl.java:362)
at org.eclipse.persistence.internal.jpa.EntityManagerImpl.createNamedQuery(EntityManagerImpl.java:1236)
at org.eclipse.persistence.internal.jpa.EntityManagerImpl.createNamedQuery(EntityManagerImpl.java:1257)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.base/java.lang.reflect.Method.invoke(Method.java:566)
Re: OpenJDK11 and eclipse link 2.7.1 Compatibility issue - Named query not found [message #1850169 is a reply to message #1849084] Fri, 18 February 2022 22:09 Go to previous message
I get the same issue, but different versions. Happens for me on Oracle jdk11, as well as openjdk 11, 16 and 17
1. eclipselink.3.0.2.jar
2. jakarta.persistence-api.3.0.0.jar
I have found that it is much more likely to happen when I have higher latency between my application and the database server. Initially found when distantly located on the network vs in the same room. Confirmed by adding bandwidth throttling to my server. Still not 100% either way, but occurs 90% of the time with throttled connection and 10% of the time with fast connection.
Previous Topic:EclipseLink fails with to connect to DB
Next Topic:EclipseLink Validation Exception in Library Eclipse Version 2.7.8
Current Time: Tue Oct 28 13:24:55 EDT 2025
Powered by FUDForum. Page generated in 0.03690 seconds
