Overwrite E3 View with Compability Layer [message #1848700] |
Tue, 14 December 2021 11:46 |
Sven Nissen Messages: 1 Registered: December 2021 |
Hi there,
I like to overwrite a view which is provided by an extension point, with an other view with the same id. I tried different approaches, but nothing seems to work.
Overwrite the view by using the E3 extension point: Does not work because of loading order. Both extension points are loaded, but the originally extension is loaded last and will be used.
E4 Modelprocessor: Everthing seems fine after the creation of the Application model, the Partdescriptors are the right ones. But after that, the viewRegistry is build, which uses the extension points and so the ApplicationModel is overwritten once again.
Application Fragment. Everything seems fine after the creation of the Application model. But after that, same as 2.
Is there a way to overwrite an existing view, with the same id, with the compability layer and E4?
Best regards Sven
FUDForum. Page generated in 0.26607 seconds
