Re: Eclipse installer oomph hangs / not responding on first step [message #1847923 is a reply to message #1847921] |
Fri, 12 November 2021 16:54   |
Michael Hitz Messages: 4 Registered: November 2021 |
thanks for your fast response. I was fearing, that this hasn't been reported before, I haven't find anything about that.
When installing, as soon as I select "Eclipse IDE for Enterprise Java and Web Developers" in the next step the window is frozen and I cannot continue. Also the default installation path provides this issue (see attached screenshot). The downloaded installer is the latest one downloaded today. I had this issue also when the old version of Eclipse was installed / available before. I removed it in order to ensure the issue was not produced by an old installed version of Eclipse. I removed the installation directory, the .p2 directory. The installation has been done on Windows 10.
Thanks again so far for your support.
best regards, Michael
[Updated on: Fri, 12 November 2021 16:55] Report message to a moderator
Re: Eclipse installer oomph hangs / not responding on first step [message #1847924 is a reply to message #1847923] |
Fri, 12 November 2021 16:59   |
To surround the issue I meanwhile downloaded the package and extracted it. I can normally start eclipse and it seems to work as expected. Is there any difference between using the installer and extracting the package with respect to the installation (except manually creation of desktop icon, etc.)? Are there some registry entries which may cause some issues?
Thanks a lot in advance.
[Updated on: Fri, 12 November 2021 17:10] Report message to a moderator
FUDForum. Page generated in 0.03061 seconds
