| Re: Installing Papyrus 6 [message #1847678 is a reply to message #1847669] | Wed, 03 November 2021 09:20  |  |
| Eclipse User  |  |  |  |  | Hmm, emx-file sounds like the model was done using the IBM Rational Software Architect.
 Ok, try to
 1. create a new empty Papyrus Model with a different name than your uml-file
 2. then copy the uml-file you received into the project directory
 3. press F5 in Papyrus to refresh the project
 4. perform a context menu -> Import -> Import Package From User Model on the top most element (should be a folder icon decorated with a triangle)
 5. follow the import wizard's process
 If the UML file you got fulfills the UML rules -- which in this case might be, because as far as I know the IBM Rational Software Architect is based on Eclipse EMF -- you at least have the model imported. No diagrams, though.
 But you can create some initial diagrams by drag'n'drop model elements onto the diagram plane of a freshly created diagram and perform a context menu -> Arrange All on the diagram.
 /Carsten
FUDForum. Page generated in 0.31836 seconds
