Unresolved inclusion of 'iostream' in a new CMake Hello World project [message #1847474] |
Thu, 28 October 2021 11:57 |
Maciej S Messages: 2 Registered: October 2021 |
I've recently switched from Eclipse 2020-03 to 2021-09 and I noticed that autocomplete feature doesn't work in either of my existing CMake projects, so I started looking for the problem with the simplest possible scenario:
I create a new Hello World CMake project within Eclipse. This compiles and runs well, but the autocomplete doesn't work already here! On the other hand, if I create the C++ Managed build then project building, running and autocomplete works (so it's not the problem with my OS or libraries). Interestingly, only the autocomplete is disabled - error highlighting works correctly.
Do you have any hints on how to fix autocomplete for CMake?
Additional background information:
- OS: Ubuntu 20.04.3, cmake version 3.16.3
- For my main projects, I generate my CMakeLists files manually, build them externally with `-G "Eclipse CDT4 - Unix Makefiles"` flag, and then import it in eclipse. This worked well in Eclipse version 2020-03, but not anymore due to autocomplete feature missing.
Re: Unresolved inclusion of 'iostream' in a new CMake Hello World project [message #1847486 is a reply to message #1847484] |
Thu, 28 October 2021 17:19 |
David Vavra Messages: 1426 Registered: October 2012 |
I guess what I find confusing is the title of your post begins:
Unresolved inclusion of 'iostream' ...
and I gave an answer to resolve it assuming it would fix the other problem.
But now you say you only meant the autocomplete issue.
I don't have an answer for that. It seems to work for me.
As for it underlining fostream you do realize that recognizing what has not
been defined is more or less independent of content assist, yes? That you can
have the former without the latter?
Have you checked that content assist has been enabled?
FUDForum. Page generated in 0.03535 seconds
