Home » Newcomers » Newcomers » Cannot complete the install because some dependencies are not satisfiable
Cannot complete the install because some dependencies are not satisfiable [message #1847344] Sat, 23 October 2021 22:16 Go to next message
Hello All,
When I was trying to install Checkstyle Plugin from:
https://marketplace.eclipse.org/marketplace-client-intro?mpc_install=150
It shows:
Cannot complete the provisioning operation. Please change your selection and try again. See below for details.
My current project is on java 11, I also had set the following in eclipse.ini, to make 1.8 my default:
-vm
/Library/Java/JavaVirtualMachines/jdk1.8.0_281.jdk/Contents/Home/jre/bin
I tried to change my environment but I could't find the solution.
If someone knows how to deal with this problem please help!
Many thanks!
Detail messages below:
Software being installed: a.jre.javase 16.0.0
Software currently installed: Eclipse Java Web Developer Tools 3.18.0.v202005181429 (org.eclipse.jst.web_ui.feature.feature.group 3.18.0.v202005181429)
Cannot satisfy dependency:
From: Eclipse Java Web Developer Tools 3.18.0.v202005181429 (org.eclipse.jst.web_ui.feature.feature.group 3.18.0.v202005181429)
To: org.eclipse.equinox.p2.iu; org.eclipse.wst.ws_ui.feature.feature.group 0.0.0
From: Web Services Tools 3.9.100.v202004082157 (org.eclipse.wst.ws_ui.feature.feature.group 3.9.100.v202004082157)
To: org.eclipse.equinox.p2.iu; org.eclipse.wst.wsdl.ui 0.0.0
From: WSDL UI 1.3.100.v202004082216 (org.eclipse.wst.wsdl.ui 1.3.100.v202004082216)
To: osgi.bundle; org.eclipse.wst.wsdl.validation [1.1.0,2.0.0)
From: WSDL Validator 1.3.0.v202101270311 (org.eclipse.wst.wsdl.validation 1.3.0.v202101270311)
To: osgi.ee; (&(osgi.ee=JavaSE)(version=11))
Re: Cannot complete the install because some dependencies are not satisfiable [message #1847356 is a reply to message #1847344] Mon, 25 October 2021 02:10 Go to previous message
Which release of Eclipse is this? Those dependencies need you to run Eclipse with Java 11 because they require Java 11.
Previous Topic:Will Eclipse 4.21 run on Mac OS 10.11.6?
Next Topic:Content Assist Broken
Current Time: Fri Oct 31 04:15:54 EDT 2025
Powered by FUDForum. Page generated in 0.08225 seconds
