Home » Eclipse Projects » GlassFish » Glassfish 6.2.2 CDI deployment failure:null
Glassfish 6.2.2 CDI deployment failure:null [message #1847238] Wed, 20 October 2021 11:48 Go to next message
I have upgraded my application from java8 to java11. However I upgraded glassfish from v.4 to v.6.2.2 to support Java11. The application is built up successfully however when I try to deploy it, it gives me an error:
    [2021-10-19T21:18:15.879+0300] [glassfish 6.2] [SEVERE] [NCLS-CORE-00026] [jakarta.enterprise.system.core] [tid: _ThreadID=61 _ThreadName=admin-listener(3)] [timeMillis: 1634667495879] [levelValue: 1000] [[
      Exception during lifecycle processing
    org.glassfish.deployment.common.DeploymentException: CDI deployment failure:null
    	at org.glassfish.weld.WeldDeployer.event(WeldDeployer.java:211)
    	at org.glassfish.kernel.event.EventsImpl.send(EventsImpl.java:107)
    	at org.glassfish.internal.data.ApplicationInfo.load(ApplicationInfo.java:304)
    	at com.sun.enterprise.v3.server.ApplicationLifecycle.deploy(ApplicationLifecycle.java:473)
    	at com.sun.enterprise.v3.server.ApplicationLifecycle.deploy(ApplicationLifecycle.java:196)
    	at org.glassfish.deployment.admin.DeployCommand.execute(DeployCommand.java:467)
    	at com.sun.enterprise.v3.admin.CommandRunnerImpl$2$1.run(CommandRunnerImpl.java:516)
    	at com.sun.enterprise.v3.admin.CommandRunnerImpl$2$1.run(CommandRunnerImpl.java:512)
    	at java.base/java.security.AccessController.doPrivileged(Native Method)
    	at java.base/javax.security.auth.Subject.doAs(Subject.java:361)
    	at com.sun.enterprise.v3.admin.CommandRunnerImpl$2.execute(CommandRunnerImpl.java:511)
    	at com.sun.enterprise.v3.admin.CommandRunnerImpl$3.run(CommandRunnerImpl.java:542)
    	at com.sun.enterprise.v3.admin.CommandRunnerImpl$3.run(CommandRunnerImpl.java:534)
    	at com.sun.enterprise.v3.admin.CommandRunnerImpl.doCommand(CommandRunnerImpl.java:533)
    	at com.sun.enterprise.v3.admin.CommandRunnerImpl.doCommand(CommandRunnerImpl.java:1441)
    	at com.sun.enterprise.v3.admin.CommandRunnerImpl$ExecutionContext.execute(CommandRunnerImpl.java:1823)
    	at com.sun.enterprise.v3.admin.CommandRunnerImpl$ExecutionContext.execute(CommandRunnerImpl.java:1699)
    	at org.glassfish.admin.rest.resources.admin.CommandResource.executeCommand(CommandResource.java:359)
    	at org.glassfish.admin.rest.resources.admin.CommandResource.execCommandSimpInMultOut(CommandResource.java:202)
    	at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
    	at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
    	at java.base/java.lang.reflect.Method.invoke(Method.java:566)
    	at org.glassfish.jersey.server.model.internal.ResourceMethodInvocationHandlerFactory.lambda$static$0(ResourceMethodInvocationHandlerFactory.java:52)
    	at org.glassfish.jersey.server.model.internal.AbstractJavaResourceMethodDispatcher$1.run(AbstractJavaResourceMethodDispatcher.java:124)
    	at org.glassfish.jersey.server.model.internal.AbstractJavaResourceMethodDispatcher.invoke(AbstractJavaResourceMethodDispatcher.java:167)
    	at org.glassfish.jersey.server.model.internal.JavaResourceMethodDispatcherProvider$ResponseOutInvoker.doDispatch(JavaResourceMethodDispatcherProvider.java:176)
    	at org.glassfish.jersey.server.model.internal.AbstractJavaResourceMethodDispatcher.dispatch(AbstractJavaResourceMethodDispatcher.java:79)
    	at org.glassfish.jersey.server.model.ResourceMethodInvoker.invoke(ResourceMethodInvoker.java:475)
    	at org.glassfish.jersey.server.model.ResourceMethodInvoker.apply(ResourceMethodInvoker.java:397)
    	at org.glassfish.jersey.server.model.ResourceMethodInvoker.apply(ResourceMethodInvoker.java:81)
    	at org.glassfish.jersey.server.ServerRuntime$1.run(ServerRuntime.java:255)
    	at org.glassfish.jersey.internal.Errors$1.call(Errors.java:248)
    	at org.glassfish.jersey.internal.Errors$1.call(Errors.java:244)
    	at org.glassfish.jersey.internal.Errors.process(Errors.java:292)
    	at org.glassfish.jersey.internal.Errors.process(Errors.java:274)
    	at org.glassfish.jersey.internal.Errors.process(Errors.java:244)
    	at org.glassfish.jersey.process.internal.RequestScope.runInScope(RequestScope.java:265)
    	at org.glassfish.jersey.server.ServerRuntime.process(ServerRuntime.java:234)
    	at org.glassfish.jersey.server.ApplicationHandler.handle(ApplicationHandler.java:684)
    	at org.glassfish.jersey.grizzly2.httpserver.GrizzlyHttpContainer.service(GrizzlyHttpContainer.java:356)
    	at org.glassfish.admin.rest.adapter.JerseyContainerCommandService$3.service(JerseyContainerCommandService.java:150)
    	at org.glassfish.admin.rest.adapter.RestAdapter.service(RestAdapter.java:156)
    	at com.sun.enterprise.v3.services.impl.ContainerMapper$HttpHandlerCallable.call(ContainerMapper.java:440)
    	at com.sun.enterprise.v3.services.impl.ContainerMapper.service(ContainerMapper.java:144)
    	at org.glassfish.grizzly.http.server.HttpHandler.runService(HttpHandler.java:174)
    	at org.glassfish.grizzly.http.server.HttpHandler.doHandle(HttpHandler.java:153)
    	at org.glassfish.grizzly.http.server.HttpServerFilter.handleRead(HttpServerFilter.java:196)
    	at org.glassfish.grizzly.filterchain.ExecutorResolver$9.execute(ExecutorResolver.java:88)
    	at org.glassfish.grizzly.filterchain.DefaultFilterChain.executeFilter(DefaultFilterChain.java:246)
    	at org.glassfish.grizzly.filterchain.DefaultFilterChain.executeChainPart(DefaultFilterChain.java:178)
    	at org.glassfish.grizzly.filterchain.DefaultFilterChain.execute(DefaultFilterChain.java:118)
    	at org.glassfish.grizzly.filterchain.DefaultFilterChain.process(DefaultFilterChain.java:96)
    	at org.glassfish.grizzly.ProcessorExecutor.execute(ProcessorExecutor.java:51)
    	at org.glassfish.grizzly.nio.transport.TCPNIOTransport.fireIOEvent(TCPNIOTransport.java:510)
    	at org.glassfish.grizzly.strategies.AbstractIOStrategy.fireIOEvent(AbstractIOStrategy.java:82)
    	at org.glassfish.grizzly.strategies.WorkerThreadIOStrategy.run0(WorkerThreadIOStrategy.java:83)
    	at org.glassfish.grizzly.strategies.WorkerThreadIOStrategy.access$100(WorkerThreadIOStrategy.java:34)
    	at org.glassfish.grizzly.strategies.WorkerThreadIOStrategy$WorkerThreadRunnable.run(WorkerThreadIOStrategy.java:101)
    	at org.glassfish.grizzly.threadpool.AbstractThreadPool$Worker.doWork(AbstractThreadPool.java:535)
    	at org.glassfish.grizzly.threadpool.AbstractThreadPool$Worker.run(AbstractThreadPool.java:515)
    	at java.base/java.lang.Thread.run(Thread.java:829)
    Caused by: java.lang.UnsupportedOperationException
    	at java.base/java.util.AbstractList.add(AbstractList.java:153)
    	at java.base/java.util.AbstractList.add(AbstractList.java:111)
    	at org.glassfish.weld.DeploymentImpl.loadBeanDeploymentArchive(DeploymentImpl.java:416)
    	at org.jboss.weld.util.DeploymentStructures.getOrCreateBeanDeployment(DeploymentStructures.java:37)
    	at org.jboss.weld.bootstrap.ExtensionBeanDeployer.deployBean(ExtensionBeanDeployer.java:82)
    	at org.jboss.weld.bootstrap.ExtensionBeanDeployer.deployBeans(ExtensionBeanDeployer.java:75)
    	at org.jboss.weld.bootstrap.WeldStartup.startInitialization(WeldStartup.java:398)
    	at org.jboss.weld.bootstrap.WeldBootstrap.startInitialization(WeldBootstrap.java:79)
    	at org.glassfish.weld.WeldDeployer.event(WeldDeployer.java:198)
    	... 63 more
    [2021-10-19T21:18:15.880+0300] [glassfish 6.2] [SEVERE] [] [jakarta.enterprise.system.core] [tid: _ThreadID=61 _ThreadName=admin-listener(3)] [timeMillis: 1634667495880] [levelValue: 1000] [[
      Exception while loading the app]]
    [2021-10-19T21:18:15.881+0300] [glassfish 6.2] [SEVERE] [AS-WEB-GLUE-00192] [jakarta.enterprise.web] [tid: _ThreadID=61 _ThreadName=admin-listener(3)] [timeMillis: 1634667495881] [levelValue: 1000] [[
      Undeployment failed for context /chesar3]]
    [2021-10-19T21:18:15.907+0300] [glassfish 6.2] [SEVERE] [] [jakarta.enterprise.system.core] [tid: _ThreadID=61 _ThreadName=admin-listener(3)] [timeMillis: 1634667495907] [levelValue: 1000] [[
      Exception while loading the app : CDI deployment failure:null
I have different approaches to deal with the error such as:
1. asadmin deploy --properties enable-implicit-cdi=false chesar3.war
2. in bean.xml : bean-discovery-mode=none, but it seems it is ignored
Any ideas?
Re: Glassfish 6.2.2 CDI deployment failure:null [message #1850265 is a reply to message #1847238] Wed, 23 February 2022 05:44 Go to previous message
Hi, this is already fixed in GlassFish 6.2.3: https://github.com/eclipse-ee4j/glassfish/pull/23683
Previous Topic:Application deployed on glassfish 6 fail to send email
Next Topic:JAX-WS with jms transport in Glassfish
Current Time: Thu Nov 06 05:23:39 EST 2025
Powered by FUDForum. Page generated in 0.02928 seconds
