Home » Modeling » EMF » EMF XML Serialization - change xsi:type to another attribute
EMF XML Serialization - change xsi:type to another attribute [message #1847166] Sun, 17 October 2021 16:27 Go to next message
this is my problem: i have a model with an abstract base class (DialogElement) and derived classes (Textbox, Textarea, etc..).
In the class DialogElement is a derived attribute "type" (EString) which is implemented to have the value of the class name of the instance. So i get
<element xsi:type="Textbox" id="firstID" type="Textbox" length="40"/>
<element xsi:type="Textarea" id="secondTextArea" type="Textarea"/>
Background: i am creating an editor for a 3rd party application without xsd schema. To be compatible, "xsi:type" needs to be
a) gone
b) renamed to "type"
I would like to change the implementation by extending an implementation class of the emf framework (i already did this for XMLHelper) but i just cannot find the class which needs to be changed.
Can somebody give me a hint?
Thank you very much.
Greetings from Cologne.
Daniel
Re: EMF XML Serialization - change xsi:type to another attribute [message #1847171 is a reply to message #1847166] Mon, 18 October 2021 02:46 Go to previous messageGo to next message
I'm a little bit doubtful that a schema can represent metadata such as xsi:type type as data. I suppose you could override org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.saveTypeAttribute(EClass) to save it differently but next you'll want to load it as well, in which case probably an org.eclipse.emf.ecore.xmi.impl.SAXXMLHandler.getXSIType() override would do the trick.
Re: EMF XML Serialization - change xsi:type to another attribute [message #1847172 is a reply to message #1847171] Mon, 18 October 2021 03:01 Go to previous messageGo to next message
Hello Ed,
i think, this is the hint / answer i needed :)
I will try it and post the result.
Thank you.
Re: EMF XML Serialization - change xsi:type to another attribute [message #1847219 is a reply to message #1847171] Tue, 19 October 2021 11:36 Go to previous message
Hello Ed,
the problem has become simpler.
Case 1: xsi:type is present
Nothing to be done. The 3rd party software ignores the attribute. So there is no need to change the serialization.
<element xsi:type="Textbox" id="textbox6" name="textbox6" type="Textbox" page="page2" section="section3" row="row14" column="column11" label="Text1"/>
Case 2: xsi:type not present (i want to load a model from the 3rd party application)
<element id="textbox6" name="textbox6" type="Textbox" page="page2" section="section3" row="row14" column="column11" label="Text1"/>
Here I extended SAXXMLHandler with my custom implementation. If the attribute "xsi:type" is missing read the value of "type", which has to contain the correct value by design.
public class DialogSAXXMLHandler extends SAXXMLHandler {
	public DialogSAXXMLHandler(XMLResource xmiResource, XMLHelper helper, Map<?, ?> options) {
		super(xmiResource, helper, options);
	protected String getXSIType() {
		String xsiValue = attribs.getValue(ExtendedMetaData.XSI_URI, XMLResource.TYPE);
		if (xsiValue == null || xsiValue.isEmpty()) {
			return attribs.getValue("type");
		return isNamespaceAware ? attribs.getValue(ExtendedMetaData.XSI_URI, XMLResource.TYPE)
				: attribs.getValue(TYPE_ATTRIB);
For those who are as clueless as i was:
I needed to extend XMLLoadImpl to get an instance of my DialogSAXXMLHandler.
public class DialogXMLLoadImpl extends XMLLoadImpl {
	public DialogXMLLoadImpl(XMLHelper helper) {
		super(helper);
		// TODO Auto-generated constructor stub
	protected DefaultHandler makeDefaultHandler() {
		return new DialogSAXXMLHandler(resource, helper, options);
The DialogXMLLoadImpl instance is created in my implementation of the Resource.
public class DialogResourceImpl extends XMLResourceImpl {
	 * Creates an instance of the resource.
	 * <!-- begin-user-doc --> <!--
	 * end-user-doc -->
	 * @param uri the URI of the new resource.
	 * @generated
	public DialogResourceImpl(URI uri) {
		super(uri);
	protected XMLHelper createXMLHelper() {
		return new DialogResourceXMLHelper();
	protected XMLLoad createXMLLoad() {
		return new DialogXMLLoadImpl(createXMLHelper());
	 * @since 2.7
	protected XMLLoad createXMLLoad(Map<?, ?> options) {
		return createXMLLoad();
	protected XMLSave createXMLSave() {
		return new DialogXMLSaveImpl(createXMLHelper());
	 * @since 2.7
	protected XMLSave createXMLSave(Map<?, ?> options) {
		return createXMLSave();
} // DialogResourceImpl
Previous Topic:XCore: Bundle 'org.eclipse.emf.ecore.xcore.lib' cannot be resolved
Next Topic:Show diagrams in a graphical manner
Current Time: Mon Oct 27 14:51:54 EDT 2025
Powered by FUDForum. Page generated in 0.03562 seconds
