Re: EClipse Help menu [message #1845083 is a reply to message #1845082] |
Wed, 06 October 2021 07:59 |
Ed Merks Messages: 33142 Registered: July 2009 |
I assume you are on Linux and that you used the installer. To install to /opt you probably use "su" to temporarily have write permission there. But the installer by default uses a shared bundle pool and by default that's in your home folder in ~/.p2/pool. So you probably ended up with a strange combination of an installation that is read only but is using a shared bundle pool that is not read only. Please read the details here and decide if you want to have a shared read-only installation or if you want to have your own personal installation:
https://www.eclipse.org/setups/installer/question/
Ed Merks
FUDForum. Page generated in 0.03835 seconds
