Home » Eclipse Projects » Eclipse Platform » Java 17 Support Patch not complete
Java 17 Support Patch not complete [message #1844927] Wed, 29 September 2021 20:49 Go to next message
Sverre Moe is currently offline Sverre MoeFriend
Member
I was able to install the Java 17 patch on Eclipse 2021-09
It was not easy by the way.
After install the following is missing:
JDK Compliance: Java Compiler Level 17
Java Execution Environment: JavaSE-17
Java 16 is the highest I can select on these two.
I can select Java 17 on Java Facets only.
Re: Java 17 Support Patch not complete [message #1845002 is a reply to message #1844927] Sat, 02 October 2021 13:25 Go to previous messageGo to next message
Rolf Theunissen is currently offline Rolf TheunissenFriend
Getting Java 17 support in JDT requires installing an additional feature from the Marketplace:
https://marketplace.eclipse.org/content/java-17-support-eclipse-2021-09-421
This should be straight forward. If you have any issue, you better ask on the JDT forum.
Re: Java 17 Support Patch not complete [message #1845006 is a reply to message #1845002] Sat, 02 October 2021 15:36 Go to previous message
Member
Yes, and I have installed it through the Marketplace.
Still something are missing.
Previous Topic:Java 17 support patch can't be installed
Next Topic:Menus on Windows 11 looks too thin
Current Time: Mon Oct 02 08:54:43 GMT 2023
Powered by FUDForum. Page generated in 0.02374 seconds
