Re: Unable to install 2021-09 behind internet and TLS firewall [message #1844792 is a reply to message #1844787] |
Sat, 25 September 2021 15:00 |
David M. Karr Messages: 802 Registered: July 2009 |
I just tried running "Perform Setup Tasks" a few times. I did notice one occurrence where it said the repository didn't exist, but without changing anything, I reran it, and it worked fine. I reran it again multiple times, and it worked each time without failure. I then tried running the installer again, verifying that it was using the same JRE as I have running Eclipse, and the installer failed each time with PKIX errors.
Note that there was something else happening around this time that I didn't mention, but it may be unrelated. I had noticed that a website that I visit several times during the day was repeatedly getting a 504 error from within the firewall, but not from anywhere else. Our CSO makes it clear when sites are blocked, so it wasn't explicitly blocked. However, late yesterday and this morning, it's having no trouble getting there. It was probably unrelated.
FUDForum. Page generated in 0.10949 seconds
