| Unable to install 2021-09 behind internet and TLS firewall [message #1844689] |
Tue, 21 September 2021 15:53  |
I work behind a firewall that also requires an intermediate root certificate for TLS. When we install a new JDK, we have to install the cert into the cacerts file of the JDK.
Every time a new release comes out, I've been able to install it with minimal trouble. I always make sure that the JDK I'm trying to use to run Eclipse has the cert installed.
I'm now trying to install 2021-09. I went into advanced mode so I could set the proxy, but when it attempts the connection, it fails with the "unable to find valid certification ..." message.
I see that there is a "SSH2 Settings" page. Do I have to import our intermediate root certificate here?
| Re: Unable to install 2021-09 behind internet and TLS firewall [message #1844792 is a reply to message #1844787] |
Sat, 25 September 2021 11:00   |
I just tried running "Perform Setup Tasks" a few times. I did notice one occurrence where it said the repository didn't exist, but without changing anything, I reran it, and it worked fine. I reran it again multiple times, and it worked each time without failure. I then tried running the installer again, verifying that it was using the same JRE as I have running Eclipse, and the installer failed each time with PKIX errors.
Note that there was something else happening around this time that I didn't mention, but it may be unrelated. I had noticed that a website that I visit several times during the day was repeatedly getting a 504 error from within the firewall, but not from anywhere else. Our CSO makes it clear when sites are blocked, so it wasn't explicitly blocked. However, late yesterday and this morning, it's having no trouble getting there. It was probably unrelated.
FUDForum. Page generated in 0.21130 seconds
