Home » Eclipse Projects » EclipseLink » JAXB throws Marshall Exception with message A descriptor with default root element was not found
JAXB throws Marshall Exception with message A descriptor with default root element was not found [message #1844635] Sun, 19 September 2021 06:25
I am trying to build jaxb objects from xsd. The xsd is "camt.054.001.04.xsd"
<!--Generated by Standards Editor (build:R1.0.41.3) on 2013 Mar 05 13:39:37, ISO 20022 version : 2013-->
<xs:schema xmlns="urn:iso:std:iso:20022:tech:xsd:camt.054.001.04" xmlns:xs="http://www.w3.org/2001/XMLSchema" elementFormDefault="qualified" targetNamespace="urn:iso:std:iso:20022:tech:xsd:camt.054.001.04">
    <xs:element name="Document" type="Document"/>
    <xs:complexType name="AccountIdentification4Choice">
        <xs:choice>
            <xs:element name="IBAN" type="IBAN2007Identifier"/>
            <xs:element name="Othr" type="GenericAccountIdentification1"/>
        </xs:choice>
    </xs:complexType>
    <xs:complexType name="AccountInterest2">
        <xs:sequence>
            <xs:element maxOccurs="1" minOccurs="0" name="Tp" type="InterestType1Choice"/>
            <xs:element maxOccurs="unbounded" minOccurs="0" name="Rate" type="Rate3"/>
            <xs:element maxOccurs="1" minOccurs="0" name="FrToDt" type="DateTimePeriodDetails"/>
            <xs:element maxOccurs="1" minOccurs="0" name="Rsn" type="Max35Text"/>
        </xs:sequence>
    </xs:complexType>
    <xs:complexType name="AccountNotification7">
        <xs:sequence>
            <xs:element name="Id" type="Max35Text"/>
            <xs:element maxOccurs="1" minOccurs="0" name="NtfctnPgntn" type="Pagination"/>
            <xs:element maxOccurs="1" minOccurs="0" name="ElctrncSeqNb" type="Number"/>
            <xs:element maxOccurs="1" minOccurs="0" name="LglSeqNb" type="Number"/>
            <xs:element name="CreDtTm" type="ISODateTime"/>
            <xs:element maxOccurs="1" minOccurs="0" name="CpyDplctInd" type="CopyDuplicate1Code"/>
            <xs:element maxOccurs="1" minOccurs="0" name="RptgSrc" type="ReportingSource1Choice"/>
            <xs:element name="Acct" type="CashAccount25"/>
            <xs:element maxOccurs="1" minOccurs="0" name="RltdAcct" type="CashAccount24"/>
            <xs:element maxOccurs="unbounded" minOccurs="0" name="Intrst" type="AccountInterest2"/>
            <xs:element maxOccurs="1" minOccurs="0" name="TxsSummry" type="TotalTransactions4"/>
            <xs:element maxOccurs="unbounded" minOccurs="0" name="Ntry" type="ReportEntry4"/>
            <xs:element maxOccurs="1" minOccurs="0" name="AddtlNtfctnInf" type="Max500Text"/>
        </xs:sequence>
    </xs:complexType>
    <xs:complexType name="AccountSchemeName1Choice">
        <xs:choice>
            <xs:element name="Cd" type="ExternalAccountIdentification1Code"/>
            <xs:element name="Prtry" type="Max35Text"/>
        </xs:choice>
    </xs:complexType>
    <xs:simpleType name="ActiveCurrencyAndAmount_SimpleType">
        <xs:restriction base="xs:decimal">
            <xs:fractionDigits value="5"/>
            <xs:totalDigits value="18"/>
            <xs:minInclusive value="0"/>
        </xs:restriction>
    </xs:simpleType>
    <xs:complexType name="ActiveCurrencyAndAmount">
        <xs:simpleContent>
            <xs:extension base="ActiveCurrencyAndAmount_SimpleType">
                <xs:attribute name="Ccy" type="ActiveCurrencyCode" use="required"/>
            </xs:extension>
        </xs:simpleContent>
    </xs:complexType>
    <xs:simpleType name="ActiveCurrencyCode">
        <xs:restriction base="xs:string">
            <xs:pattern value="[A-Z]{3,3}"/>
        </xs:restriction>
    </xs:simpleType>
    <xs:simpleType name="ActiveOrHistoricCurrencyAnd13DecimalAmount_SimpleType">
            <xs:fractionDigits value="13"/>
        </xs:restriction>
    </xs:simpleType>
    <xs:complexType name="ActiveOrHistoricCurrencyAnd13DecimalAmount">
        <xs:simpleContent>
            <xs:extension base="ActiveOrHistoricCurrencyAnd13DecimalAmount_SimpleType">
                <xs:attribute name="Ccy" type="ActiveOrHistoricCurrencyCode" use="required"/>
            </xs:extension>
        </xs:simpleContent>
    </xs:complexType>
    <xs:simpleType name="ActiveOrHistoricCurrencyAndAmount_SimpleType">
        </xs:restriction>
    </xs:simpleType>
    <xs:complexType name="ActiveOrHistoricCurrencyAndAmount">
        <xs:simpleContent>
            <xs:extension base="ActiveOrHistoricCurrencyAndAmount_SimpleType">
            </xs:extension>
        </xs:simpleContent>
    </xs:complexType>
    <xs:simpleType name="ActiveOrHistoricCurrencyCode">
        </xs:restriction>
    </xs:simpleType>
    <xs:simpleType name="AddressType2Code">
            <xs:enumeration value="ADDR"/>
            <xs:enumeration value="PBOX"/>
            <xs:enumeration value="HOME"/>
            <xs:enumeration value="BIZZ"/>
            <xs:enumeration value="MLTO"/>
            <xs:enumeration value="DLVY"/>
        </xs:restriction>
    </xs:simpleType>
    <xs:complexType name="AmountAndCurrencyExchange3">
        <xs:sequence>
            <xs:element maxOccurs="1" minOccurs="0" name="InstdAmt" type="AmountAndCurrencyExchangeDetails3"/>
            <xs:element maxOccurs="1" minOccurs="0" name="TxAmt" type="AmountAndCurrencyExchangeDetails3"/>
            <xs:element maxOccurs="1" minOccurs="0" name="CntrValAmt" type="AmountAndCurrencyExchangeDetails3"/>
            <xs:element maxOccurs="1" minOccurs="0" name="AnncdPstngAmt" type="AmountAndCurrencyExchangeDetails3"/>
            <xs:element maxOccurs="unbounded" minOccurs="0" name="PrtryAmt" type="AmountAndCurrencyExchangeDetails4"/>
        </xs:sequence>
    </xs:complexType>
    <xs:complexType name="AmountAndCurrencyExchangeDetails3">
        <xs:sequence>
            <xs:element name="Amt" type="ActiveOrHistoricCurrencyAndAmount"/>
            <xs:element maxOccurs="1" minOccurs="0" name="CcyXchg" type="CurrencyExchange5"/>
        </xs:sequence>
    </xs:complexType>
    <xs:complexType name="AmountAndCurrencyExchangeDetails4">
        <xs:sequence>
            <xs:element name="Tp" type="Max35Text"/>
        </xs:sequence>
    </xs:complexType>
    <xs:complexType name="AmountAndDirection35">
        <xs:sequence>
            <xs:element name="Amt" type="NonNegativeDecimalNumber"/>
            <xs:element name="CdtDbtInd" type="CreditDebitCode"/>
        </xs:sequence>
    </xs:complexType>
    <xs:complexType name="AmountRangeBoundary1">
        <xs:sequence>
            <xs:element name="BdryAmt" type="ImpliedCurrencyAndAmount"/>
            <xs:element name="Incl" type="YesNoIndicator"/>
        </xs:sequence>
    </xs:complexType>
    <xs:simpleType name="AnyBICIdentifier">
            <xs:pattern value="[A-Z]{6,6}[A-Z2-9][A-NP-Z0-9]([A-Z0-9]{3,3}){0,1}"/>
        </xs:restriction>
    </xs:simpleType>
    <xs:simpleType name="BICFIIdentifier">
        </xs:restriction>
    </xs:simpleType>
    <xs:complexType name="BankToCustomerDebitCreditNotificationV04">
        <xs:sequence>
            <xs:element name="GrpHdr" type="GroupHeader58"/>
            <xs:element maxOccurs="unbounded" minOccurs="1" name="Ntfctn" type="AccountNotification7"/>
            <xs:element maxOccurs="unbounded" minOccurs="0" name="SplmtryData" type="SupplementaryData1"/>
        </xs:sequence>
    </xs:complexType>
    <xs:complexType name="BankTransactionCodeStructure4">
        <xs:sequence>
            <xs:element maxOccurs="1" minOccurs="0" name="Domn" type="BankTransactionCodeStructure5"/>
            <xs:element maxOccurs="1" minOccurs="0" name="Prtry" type="ProprietaryBankTransactionCodeStructure1"/>
        </xs:sequence>
    </xs:complexType>
    <xs:complexType name="BankTransactionCodeStructure5">
        <xs:sequence>
            <xs:element name="Cd" type="ExternalBankTransactionDomain1Code"/>
            <xs:element name="Fmly" type="BankTransactionCodeStructure6"/>
        </xs:sequence>
    </xs:complexType>
    <xs:complexType name="BankTransactionCodeStructure6">
        <xs:sequence>
            <xs:element name="Cd" type="ExternalBankTransactionFamily1Code"/>
            <xs:element name="SubFmlyCd" type="ExternalBankTransactionSubFamily1Code"/>
        </xs:sequence>
    </xs:complexType>
    <xs:simpleType name="BaseOneRate">
            <xs:fractionDigits value="10"/>
            <xs:totalDigits value="11"/>
        </xs:restriction>
    </xs:simpleType>
    <xs:complexType name="BatchInformation2">
        <xs:sequence>
            <xs:element maxOccurs="1" minOccurs="0" name="MsgId" type="Max35Text"/>
            <xs:element maxOccurs="1" minOccurs="0" name="PmtInfId" type="Max35Text"/>
            <xs:element maxOccurs="1" minOccurs="0" name="NbOfTxs" type="Max15NumericText"/>
            <xs:element maxOccurs="1" minOccurs="0" name="TtlAmt" type="ActiveOrHistoricCurrencyAndAmount"/>
            <xs:element maxOccurs="1" minOccurs="0" name="CdtDbtInd" type="CreditDebitCode"/>
        </xs:sequence>
    </xs:complexType>
    <xs:complexType name="BranchAndFinancialInstitutionIdentification5">
        <xs:sequence>
            <xs:element name="FinInstnId" type="FinancialInstitutionIdentification8"/>
            <xs:element maxOccurs="1" minOccurs="0" name="BrnchId" type="BranchData2"/>
        </xs:sequence>
    </xs:complexType>
    <xs:complexType name="BranchData2">
        <xs:sequence>
            <xs:element maxOccurs="1" minOccurs="0" name="Id" type="Max35Text"/>
            <xs:element maxOccurs="1" minOccurs="0" name="Nm" type="Max140Text"/>
            <xs:element maxOccurs="1" minOccurs="0" name="PstlAdr" type="PostalAddress6"/>
        </xs:sequence>
    </xs:complexType>
    <xs:simpleType name="CSCManagement1Code">
            <xs:enumeration value="PRST"/>
            <xs:enumeration value="BYPS"/>
            <xs:enumeration value="UNRD"/>
            <xs:enumeration value="NCSC"/>
        </xs:restriction>
    </xs:simpleType>
    <xs:complexType name="CardAggregated1">
        <xs:sequence>
            <xs:element maxOccurs="1" minOccurs="0" name="AddtlSvc" type="CardPaymentServiceType2Code"/>
            <xs:element maxOccurs="1" minOccurs="0" name="TxCtgy" type="ExternalCardTransactionCategory1Code"/>
            <xs:element maxOccurs="1" minOccurs="0" name="SaleRcncltnId" type="Max35Text"/>
            <xs:element maxOccurs="1" minOccurs="0" name="SeqNbRg" type="CardSequenceNumberRange1"/>
            <xs:element maxOccurs="1" minOccurs="0" name="TxDtRg" type="DateOrDateTimePeriodChoice"/>
        </xs:sequence>
    </xs:complexType>
    <xs:simpleType name="CardDataReading1Code">
            <xs:enumeration value="TAGC"/>
            <xs:enumeration value="PHYS"/>
            <xs:enumeration value="BRCD"/>
            <xs:enumeration value="MGST"/>
            <xs:enumeration value="CICC"/>
            <xs:enumeration value="DFLE"/>
            <xs:enumeration value="CTLS"/>
            <xs:enumeration value="ECTL"/>
        </xs:restriction>
    </xs:simpleType>
    <xs:complexType name="CardEntry1">
        <xs:sequence>
            <xs:element maxOccurs="1" minOccurs="0" name="Card" type="PaymentCard4"/>
            <xs:element maxOccurs="1" minOccurs="0" name="POI" type="PointOfInteraction1"/>
            <xs:element maxOccurs="1" minOccurs="0" name="AggtdNtry" type="CardAggregated1"/>
        </xs:sequence>
    </xs:complexType>
    <xs:complexType name="CardIndividualTransaction1">
        <xs:sequence>
            <xs:element maxOccurs="1" minOccurs="0" name="SaleRefNb" type="Max35Text"/>
            <xs:element maxOccurs="1" minOccurs="0" name="SeqNb" type="Max35Text"/>
            <xs:element maxOccurs="1" minOccurs="0" name="TxId" type="TransactionIdentifier1"/>
            <xs:element maxOccurs="1" minOccurs="0" name="Pdct" type="Product2"/>
            <xs:element maxOccurs="1" minOccurs="0" name="VldtnDt" type="ISODate"/>
            <xs:element maxOccurs="1" minOccurs="0" name="VldtnSeqNb" type="Max35Text"/>
        </xs:sequence>
    </xs:complexType>
    <xs:simpleType name="CardPaymentServiceType2Code">
            <xs:enumeration value="AGGR"/>
            <xs:enumeration value="DCCV"/>
            <xs:enumeration value="GRTT"/>
            <xs:enumeration value="INSP"/>
            <xs:enumeration value="LOYT"/>
            <xs:enumeration value="NRES"/>
            <xs:enumeration value="PUCO"/>
            <xs:enumeration value="RECP"/>
            <xs:enumeration value="SOAF"/>
            <xs:enumeration value="UNAF"/>
            <xs:enumeration value="VCAU"/>
        </xs:restriction>
    </xs:simpleType>
    <xs:complexType name="CardSecurityInformation1">
        <xs:sequence>
            <xs:element name="CSCMgmt" type="CSCManagement1Code"/>
            <xs:element maxOccurs="1" minOccurs="0" name="CSCVal" type="Min3Max4NumericText"/>
        </xs:sequence>
    </xs:complexType>
    <xs:complexType name="CardSequenceNumberRange1">
        <xs:sequence>
            <xs:element maxOccurs="1" minOccurs="0" name="FrstTx" type="Max35Text"/>
            <xs:element maxOccurs="1" minOccurs="0" name="LastTx" type="Max35Text"/>
        </xs:sequence>
    </xs:complexType>
    <xs:complexType name="CardTransaction1">
        <xs:sequence>
            <xs:element maxOccurs="1" minOccurs="0" name="Tx" type="CardTransaction1Choice"/>
        </xs:sequence>
    </xs:complexType>
    <xs:complexType name="CardTransaction1Choice">
        <xs:choice>
            <xs:element name="Aggtd" type="CardAggregated1"/>
            <xs:element name="Indv" type="CardIndividualTransaction1"/>
        </xs:choice>
    </xs:complexType>
    <xs:simpleType name="CardholderVerificationCapability1Code">
            <xs:enumeration value="MNSG"/>
            <xs:enumeration value="NPIN"/>
            <xs:enumeration value="FCPN"/>
            <xs:enumeration value="FEPN"/>
            <xs:enumeration value="FDSG"/>
            <xs:enumeration value="FBIO"/>
            <xs:enumeration value="MNVR"/>
            <xs:enumeration value="FBIG"/>
            <xs:enumeration value="APKI"/>
            <xs:enumeration value="PKIS"/>
            <xs:enumeration value="CHDT"/>
            <xs:enumeration value="SCEC"/>
        </xs:restriction>
    </xs:simpleType>
    <xs:complexType name="CashAccount24">
        <xs:sequence>
            <xs:element name="Id" type="AccountIdentification4Choice"/>
            <xs:element maxOccurs="1" minOccurs="0" name="Tp" type="CashAccountType2Choice"/>
            <xs:element maxOccurs="1" minOccurs="0" name="Ccy" type="ActiveOrHistoricCurrencyCode"/>
            <xs:element maxOccurs="1" minOccurs="0" name="Nm" type="Max70Text"/>
        </xs:sequence>
    </xs:complexType>
    <xs:complexType name="CashAccount25">
        <xs:sequence>
            <xs:element maxOccurs="1" minOccurs="0" name="Ownr" type="PartyIdentification43"/>
            <xs:element maxOccurs="1" minOccurs="0" name="Svcr" type="BranchAndFinancialInstitutionIdentification5"/>
        </xs:sequence>
    </xs:complexType>
    <xs:complexType name="CashAccountType2Choice">
        <xs:choice>
            <xs:element name="Cd" type="ExternalCashAccountType1Code"/>
        </xs:choice>
    </xs:complexType>
    <xs:complexType name="CashBalanceAvailability2">
        <xs:sequence>
            <xs:element name="Dt" type="CashBalanceAvailabilityDate1"/>
        </xs:sequence>
    </xs:complexType>
    <xs:complexType name="CashBalanceAvailabilityDate1">
        <xs:sequence>
            <xs:choice>
                <xs:element name="NbOfDays" type="Max15PlusSignedNumericText"/>
                <xs:element name="ActlDt" type="ISODate"/>
            </xs:choice>
        </xs:sequence>
    </xs:complexType>
    <xs:complexType name="CashDeposit1">
        <xs:sequence>
            <xs:element name="NoteDnmtn" type="ActiveCurrencyAndAmount"/>
            <xs:element name="NbOfNotes" type="Max15NumericText"/>
            <xs:element name="Amt" type="ActiveCurrencyAndAmount"/>
        </xs:sequence>
    </xs:complexType>
    <xs:simpleType name="ChargeBearerType1Code">
            <xs:enumeration value="DEBT"/>
            <xs:enumeration value="CRED"/>
            <xs:enumeration value="SHAR"/>
            <xs:enumeration value="SLEV"/>
        </xs:restriction>
    </xs:simpleType>
    <xs:simpleType name="ChargeIncludedIndicator">
        <xs:restriction base="xs:boolean"/>
    </xs:simpleType>
    <xs:complexType name="ChargeType3Choice">
        <xs:choice>
            <xs:element name="Cd" type="ExternalChargeType1Code"/>
            <xs:element name="Prtry" type="GenericIdentification3"/>
        </xs:choice>
    </xs:complexType>
    <xs:complexType name="Charges4">
        <xs:sequence>
            <xs:element maxOccurs="1" minOccurs="0" name="TtlChrgsAndTaxAmt" type="ActiveOrHistoricCurrencyAndAmount"/>
            <xs:element maxOccurs="unbounded" minOccurs="0" name="Rcrd" type="ChargesRecord2"/>
        </xs:sequence>
    </xs:complexType>
    <xs:complexType name="ChargesRecord2">
        <xs:sequence>
            <xs:element maxOccurs="1" minOccurs="0" name="ChrgInclInd" type="ChargeIncludedIndicator"/>
            <xs:element maxOccurs="1" minOccurs="0" name="Tp" type="ChargeType3Choice"/>
            <xs:element maxOccurs="1" minOccurs="0" name="Rate" type="PercentageRate"/>
            <xs:element maxOccurs="1" minOccurs="0" name="Br" type="ChargeBearerType1Code"/>
            <xs:element maxOccurs="1" minOccurs="0" name="Agt" type="BranchAndFinancialInstitutionIdentification5"/>
            <xs:element maxOccurs="1" minOccurs="0" name="Tax" type="TaxCharges2"/>
        </xs:sequence>
    </xs:complexType>
    <xs:complexType name="ClearingSystemIdentification2Choice">
        <xs:choice>
            <xs:element name="Cd" type="ExternalClearingSystemIdentification1Code"/>
        </xs:choice>
    </xs:complexType>
    <xs:complexType name="ClearingSystemMemberIdentification2">
        <xs:sequence>
            <xs:element maxOccurs="1" minOccurs="0" name="ClrSysId" type="ClearingSystemIdentification2Choice"/>
            <xs:element name="MmbId" type="Max35Text"/>
        </xs:sequence>
    </xs:complexType>
    <xs:complexType name="ContactDetails2">
        <xs:sequence>
            <xs:element maxOccurs="1" minOccurs="0" name="NmPrfx" type="NamePrefix1Code"/>
            <xs:element maxOccurs="1" minOccurs="0" name="PhneNb" type="PhoneNumber"/>
            <xs:element maxOccurs="1" minOccurs="0" name="MobNb" type="PhoneNumber"/>
            <xs:element maxOccurs="1" minOccurs="0" name="FaxNb" type="PhoneNumber"/>
            <xs:element maxOccurs="1" minOccurs="0" name="EmailAdr" type="Max2048Text"/>
            <xs:element maxOccurs="1" minOccurs="0" name="Othr" type="Max35Text"/>
        </xs:sequence>
    </xs:complexType>
    <xs:simpleType name="CopyDuplicate1Code">
            <xs:enumeration value="CODU"/>
            <xs:enumeration value="COPY"/>
            <xs:enumeration value="DUPL"/>
        </xs:restriction>
    </xs:simpleType>
    <xs:complexType name="CorporateAction9">
        <xs:sequence>
            <xs:element name="EvtTp" type="Max35Text"/>
            <xs:element name="EvtId" type="Max35Text"/>
        </xs:sequence>
    </xs:complexType>
    <xs:simpleType name="CountryCode">
            <xs:pattern value="[A-Z]{2,2}"/>
        </xs:restriction>
    </xs:simpleType>
    <xs:simpleType name="CreditDebitCode">
            <xs:enumeration value="CRDT"/>
            <xs:enumeration value="DBIT"/>
        </xs:restriction>
    </xs:simpleType>
    <xs:complexType name="CreditorReferenceInformation2">
        <xs:sequence>
            <xs:element maxOccurs="1" minOccurs="0" name="Tp" type="CreditorReferenceType2"/>
            <xs:element maxOccurs="1" minOccurs="0" name="Ref" type="Max35Text"/>
        </xs:sequence>
    </xs:complexType>
    <xs:complexType name="CreditorReferenceType1Choice">
        <xs:choice>
            <xs:element name="Cd" type="DocumentType3Code"/>
        </xs:choice>
    </xs:complexType>
    <xs:complexType name="CreditorReferenceType2">
        <xs:sequence>
            <xs:element name="CdOrPrtry" type="CreditorReferenceType1Choice"/>
            <xs:element maxOccurs="1" minOccurs="0" name="Issr" type="Max35Text"/>
        </xs:sequence>
    </xs:complexType>
    <xs:complexType name="CurrencyAndAmountRange2">
        <xs:sequence>
            <xs:element name="Amt" type="ImpliedCurrencyAmountRangeChoice"/>
            <xs:element name="Ccy" type="ActiveOrHistoricCurrencyCode"/>
        </xs:sequence>
    </xs:complexType>
    <xs:complexType name="CurrencyExchange5">
        <xs:sequence>
            <xs:element name="SrcCcy" type="ActiveOrHistoricCurrencyCode"/>
            <xs:element maxOccurs="1" minOccurs="0" name="TrgtCcy" type="ActiveOrHistoricCurrencyCode"/>
            <xs:element maxOccurs="1" minOccurs="0" name="UnitCcy" type="ActiveOrHistoricCurrencyCode"/>
            <xs:element name="XchgRate" type="BaseOneRate"/>
            <xs:element maxOccurs="1" minOccurs="0" name="CtrctId" type="Max35Text"/>
            <xs:element maxOccurs="1" minOccurs="0" name="QtnDt" type="ISODateTime"/>
        </xs:sequence>
    </xs:complexType>
    <xs:complexType name="DateAndDateTimeChoice">
        <xs:choice>
            <xs:element name="Dt" type="ISODate"/>
            <xs:element name="DtTm" type="ISODateTime"/>
        </xs:choice>
    </xs:complexType>
    <xs:complexType name="DateAndPlaceOfBirth">
        <xs:sequence>
            <xs:element name="BirthDt" type="ISODate"/>
            <xs:element maxOccurs="1" minOccurs="0" name="PrvcOfBirth" type="Max35Text"/>
            <xs:element name="CityOfBirth" type="Max35Text"/>
            <xs:element name="CtryOfBirth" type="CountryCode"/>
        </xs:sequence>
    </xs:complexType>
    <xs:complexType name="DateOrDateTimePeriodChoice">
        <xs:choice>
            <xs:element name="Dt" type="DatePeriodDetails"/>
            <xs:element name="DtTm" type="DateTimePeriodDetails"/>
        </xs:choice>
    </xs:complexType>
    <xs:complexType name="DatePeriodDetails">
        <xs:sequence>
            <xs:element name="FrDt" type="ISODate"/>
            <xs:element name="ToDt" type="ISODate"/>
        </xs:sequence>
    </xs:complexType>
    <xs:complexType name="DateTimePeriodDetails">
        <xs:sequence>
            <xs:element name="FrDtTm" type="ISODateTime"/>
            <xs:element name="ToDtTm" type="ISODateTime"/>
        </xs:sequence>
    </xs:complexType>
    <xs:simpleType name="DecimalNumber">
            <xs:fractionDigits value="17"/>
        </xs:restriction>
    </xs:simpleType>
    <xs:complexType name="DiscountAmountAndType1">
        <xs:sequence>
            <xs:element maxOccurs="1" minOccurs="0" name="Tp" type="DiscountAmountType1Choice"/>
        </xs:sequence>
    </xs:complexType>
    <xs:complexType name="DiscountAmountType1Choice">
        <xs:choice>
            <xs:element name="Cd" type="ExternalDiscountAmountType1Code"/>
        </xs:choice>
    </xs:complexType>
    <xs:complexType name="DisplayCapabilities1">
        <xs:sequence>
            <xs:element name="DispTp" type="UserInterface2Code"/>
            <xs:element name="NbOfLines" type="Max3NumericText"/>
            <xs:element name="LineWidth" type="Max3NumericText"/>
        </xs:sequence>
    </xs:complexType>
    <xs:complexType name="Document">
        <xs:sequence>
            <xs:element name="BkToCstmrDbtCdtNtfctn" type="BankToCustomerDebitCreditNotificationV04"/>
        </xs:sequence>
    </xs:complexType>
    <xs:complexType name="DocumentAdjustment1">
        <xs:sequence>
            <xs:element maxOccurs="1" minOccurs="0" name="Rsn" type="Max4Text"/>
            <xs:element maxOccurs="1" minOccurs="0" name="AddtlInf" type="Max140Text"/>
        </xs:sequence>
    </xs:complexType>
    <xs:simpleType name="DocumentType3Code">
            <xs:enumeration value="RADM"/>
            <xs:enumeration value="RPIN"/>
            <xs:enumeration value="FXDR"/>
            <xs:enumeration value="DISP"/>
            <xs:enumeration value="PUOR"/>
            <xs:enumeration value="SCOR"/>
        </xs:restriction>
    </xs:simpleType>
    <xs:simpleType name="DocumentType5Code">
            <xs:enumeration value="MSIN"/>
            <xs:enumeration value="CNFA"/>
            <xs:enumeration value="DNFA"/>
            <xs:enumeration value="CINV"/>
            <xs:enumeration value="CREN"/>
            <xs:enumeration value="DEBN"/>
            <xs:enumeration value="HIRI"/>
            <xs:enumeration value="SBIN"/>
            <xs:enumeration value="CMCN"/>
            <xs:enumeration value="SOAC"/>
            <xs:enumeration value="BOLD"/>
            <xs:enumeration value="VCHR"/>
            <xs:enumeration value="AROI"/>
            <xs:enumeration value="TSUT"/>
        </xs:restriction>
    </xs:simpleType>
    <xs:complexType name="EntryDetails3">
        <xs:sequence>
            <xs:element maxOccurs="1" minOccurs="0" name="Btch" type="BatchInformation2"/>
            <xs:element maxOccurs="unbounded" minOccurs="0" name="TxDtls" type="EntryTransaction4"/>
        </xs:sequence>
    </xs:complexType>
    <xs:simpleType name="EntryStatus2Code">
            <xs:enumeration value="BOOK"/>
            <xs:enumeration value="PDNG"/>
            <xs:enumeration value="INFO"/>
        </xs:restriction>
    </xs:simpleType>
    <xs:complexType name="EntryTransaction4">
        <xs:sequence>
            <xs:element maxOccurs="1" minOccurs="0" name="Refs" type="TransactionReferences3"/>
            <xs:element maxOccurs="1" minOccurs="0" name="AmtDtls" type="AmountAndCurrencyExchange3"/>
            <xs:element maxOccurs="unbounded" minOccurs="0" name="Avlbty" type="CashBalanceAvailability2"/>
            <xs:element maxOccurs="1" minOccurs="0" name="BkTxCd" type="BankTransactionCodeStructure4"/>
            <xs:element maxOccurs="1" minOccurs="0" name="Chrgs" type="Charges4"/>
            <xs:element maxOccurs="1" minOccurs="0" name="Intrst" type="TransactionInterest3"/>
            <xs:element maxOccurs="1" minOccurs="0" name="RltdPties" type="TransactionParties3"/>
            <xs:element maxOccurs="1" minOccurs="0" name="RltdAgts" type="TransactionAgents3"/>
            <xs:element maxOccurs="1" minOccurs="0" name="Purp" type="Purpose2Choice"/>
            <xs:element maxOccurs="10" minOccurs="0" name="RltdRmtInf" type="RemittanceLocation2"/>
            <xs:element maxOccurs="1" minOccurs="0" name="RmtInf" type="RemittanceInformation7"/>
            <xs:element maxOccurs="1" minOccurs="0" name="RltdDts" type="TransactionDates2"/>
            <xs:element maxOccurs="1" minOccurs="0" name="RltdPric" type="TransactionPrice3Choice"/>
            <xs:element maxOccurs="unbounded" minOccurs="0" name="RltdQties" type="TransactionQuantities2Choice"/>
            <xs:element maxOccurs="1" minOccurs="0" name="FinInstrmId" type="SecurityIdentification14"/>
            <xs:element maxOccurs="1" minOccurs="0" name="Tax" type="TaxInformation3"/>
            <xs:element maxOccurs="1" minOccurs="0" name="RtrInf" type="PaymentReturnReason2"/>
            <xs:element maxOccurs="1" minOccurs="0" name="CorpActn" type="CorporateAction9"/>
            <xs:element maxOccurs="1" minOccurs="0" name="SfkpgAcct" type="SecuritiesAccount13"/>
            <xs:element maxOccurs="unbounded" minOccurs="0" name="CshDpst" type="CashDeposit1"/>
            <xs:element maxOccurs="1" minOccurs="0" name="CardTx" type="CardTransaction1"/>
            <xs:element maxOccurs="1" minOccurs="0" name="AddtlTxInf" type="Max500Text"/>
        </xs:sequence>
    </xs:complexType>
    <xs:simpleType name="Exact1NumericText">
            <xs:pattern value="[0-9]"/>
        </xs:restriction>
    </xs:simpleType>
    <xs:simpleType name="Exact3NumericText">
            <xs:pattern value="[0-9]{3}"/>
        </xs:restriction>
    </xs:simpleType>
    <xs:simpleType name="Exact4AlphaNumericText">
            <xs:pattern value="[a-zA-Z0-9]{4}"/>
        </xs:restriction>
    </xs:simpleType>
    <xs:simpleType name="ExternalAccountIdentification1Code">
            <xs:minLength value="1"/>
            <xs:maxLength value="4"/>
        </xs:restriction>
    </xs:simpleType>
    <xs:simpleType name="ExternalBankTransactionDomain1Code">
        </xs:restriction>
    </xs:simpleType>
    <xs:simpleType name="ExternalBankTransactionFamily1Code">
        </xs:restriction>
    </xs:simpleType>
    <xs:simpleType name="ExternalBankTransactionSubFamily1Code">
        </xs:restriction>
    </xs:simpleType>
    <xs:simpleType name="ExternalCardTransactionCategory1Code">
        </xs:restriction>
    </xs:simpleType>
    <xs:simpleType name="ExternalCashAccountType1Code">
        </xs:restriction>
    </xs:simpleType>
    <xs:simpleType name="ExternalChargeType1Code">
        </xs:restriction>
    </xs:simpleType>
    <xs:simpleType name="ExternalClearingSystemIdentification1Code">
            <xs:maxLength value="5"/>
        </xs:restriction>
    </xs:simpleType>
    <xs:simpleType name="ExternalDiscountAmountType1Code">
        </xs:restriction>
    </xs:simpleType>
    <xs:simpleType name="ExternalFinancialInstitutionIdentification1Code">
        </xs:restriction>
    </xs:simpleType>
    <xs:simpleType name="ExternalFinancialInstrumentIdentificationType1Code">
        </xs:restriction>
    </xs:simpleType>
    <xs:simpleType name="ExternalOrganisationIdentification1Code">
        </xs:restriction>
    </xs:simpleType>
    <xs:simpleType name="ExternalPersonIdentification1Code">
        </xs:restriction>
    </xs:simpleType>
    <xs:simpleType name="ExternalPurpose1Code">
        </xs:restriction>
    </xs:simpleType>
    <xs:simpleType name="ExternalReportingSource1Code">
        </xs:restriction>
    </xs:simpleType>
    <xs:simpleType name="ExternalReturnReason1Code">
        </xs:restriction>
    </xs:simpleType>
    <xs:simpleType name="ExternalTaxAmountType1Code">
        </xs:restriction>
    </xs:simpleType>
    <xs:simpleType name="ExternalTechnicalInputChannel1Code">
        </xs:restriction>
    </xs:simpleType>
    <xs:complexType name="FinancialIdentificationSchemeName1Choice">
        <xs:choice>
            <xs:element name="Cd" type="ExternalFinancialInstitutionIdentification1Code"/>
        </xs:choice>
    </xs:complexType>
    <xs:complexType name="FinancialInstitutionIdentification8">
        <xs:sequence>
            <xs:element maxOccurs="1" minOccurs="0" name="BICFI" type="BICFIIdentifier"/>
            <xs:element maxOccurs="1" minOccurs="0" name="ClrSysMmbId" type="ClearingSystemMemberIdentification2"/>
            <xs:element maxOccurs="1" minOccurs="0" name="Othr" type="GenericFinancialIdentification1"/>
        </xs:sequence>
    </xs:complexType>
    <xs:complexType name="FinancialInstrumentQuantityChoice">
        <xs:choice>
            <xs:element name="Unit" type="DecimalNumber"/>
            <xs:element name="FaceAmt" type="ImpliedCurrencyAndAmount"/>
            <xs:element name="AmtsdVal" type="ImpliedCurrencyAndAmount"/>
        </xs:choice>
    </xs:complexType>
    <xs:complexType name="FromToAmountRange">
        <xs:sequence>
            <xs:element name="FrAmt" type="AmountRangeBoundary1"/>
            <xs:element name="ToAmt" type="AmountRangeBoundary1"/>
        </xs:sequence>
    </xs:complexType>
    <xs:complexType name="GenericAccountIdentification1">
        <xs:sequence>
            <xs:element name="Id" type="Max34Text"/>
            <xs:element maxOccurs="1" minOccurs="0" name="SchmeNm" type="AccountSchemeName1Choice"/>
        </xs:sequence>
    </xs:complexType>
    <xs:complexType name="GenericFinancialIdentification1">
        <xs:sequence>
            <xs:element maxOccurs="1" minOccurs="0" name="SchmeNm" type="FinancialIdentificationSchemeName1Choice"/>
        </xs:sequence>
    </xs:complexType>
    <xs:complexType name="GenericIdentification1">
        <xs:sequence>
            <xs:element maxOccurs="1" minOccurs="0" name="SchmeNm" type="Max35Text"/>
        </xs:sequence>
    </xs:complexType>
    <xs:complexType name="GenericIdentification20">
        <xs:sequence>
            <xs:element name="Id" type="Exact4AlphaNumericText"/>
            <xs:element name="Issr" type="Max35Text"/>
        </xs:sequence>
    </xs:complexType>
    <xs:complexType name="GenericIdentification3">
        <xs:sequence>
        </xs:sequence>
    </xs:complexType>
    <xs:complexType name="GenericIdentification32">
        <xs:sequence>
            <xs:element maxOccurs="1" minOccurs="0" name="Tp" type="PartyType3Code"/>
            <xs:element maxOccurs="1" minOccurs="0" name="Issr" type="PartyType4Code"/>
            <xs:element maxOccurs="1" minOccurs="0" name="ShrtNm" type="Max35Text"/>
        </xs:sequence>
    </xs:complexType>
    <xs:complexType name="GenericOrganisationIdentification1">
        <xs:sequence>
            <xs:element maxOccurs="1" minOccurs="0" name="SchmeNm" type="OrganisationIdentificationSchemeName1Choice"/>
        </xs:sequence>
    </xs:complexType>
    <xs:complexType name="GenericPersonIdentification1">
        <xs:sequence>
            <xs:element maxOccurs="1" minOccurs="0" name="SchmeNm" type="PersonIdentificationSchemeName1Choice"/>
        </xs:sequence>
    </xs:complexType>
    <xs:complexType name="GroupHeader58">
        <xs:sequence>
            <xs:element name="MsgId" type="Max35Text"/>
            <xs:element maxOccurs="1" minOccurs="0" name="MsgRcpt" type="PartyIdentification43"/>
            <xs:element maxOccurs="1" minOccurs="0" name="MsgPgntn" type="Pagination"/>
            <xs:element maxOccurs="1" minOccurs="0" name="OrgnlBizQry" type="OriginalBusinessQuery1"/>
            <xs:element maxOccurs="1" minOccurs="0" name="AddtlInf" type="Max500Text"/>
        </xs:sequence>
    </xs:complexType>
    <xs:simpleType name="IBAN2007Identifier">
            <xs:pattern value="[A-Z]{2,2}[0-9]{2,2}[a-zA-Z0-9]{1,30}"/>
        </xs:restriction>
    </xs:simpleType>
    <xs:simpleType name="ISINIdentifier">
            <xs:pattern value="[A-Z0-9]{12,12}"/>
        </xs:restriction>
    </xs:simpleType>
    <xs:simpleType name="ISODate">
        <xs:restriction base="xs:date"/>
    </xs:simpleType>
    <xs:simpleType name="ISODateTime">
        <xs:restriction base="xs:dateTime"/>
    </xs:simpleType>
    <xs:simpleType name="ISOYearMonth">
        <xs:restriction base="xs:gYearMonth"/>
    </xs:simpleType>
    <xs:complexType name="IdentificationSource3Choice">
        <xs:choice>
            <xs:element name="Cd" type="ExternalFinancialInstrumentIdentificationType1Code"/>
        </xs:choice>
    </xs:complexType>
    <xs:complexType name="ImpliedCurrencyAmountRangeChoice">
        <xs:choice>
            <xs:element name="FrToAmt" type="FromToAmountRange"/>
            <xs:element name="EQAmt" type="ImpliedCurrencyAndAmount"/>
            <xs:element name="NEQAmt" type="ImpliedCurrencyAndAmount"/>
        </xs:choice>
    </xs:complexType>
    <xs:simpleType name="ImpliedCurrencyAndAmount">
        </xs:restriction>
    </xs:simpleType>
    <xs:complexType name="InterestRecord1">
        <xs:sequence>
            <xs:element maxOccurs="1" minOccurs="0" name="Rate" type="Rate3"/>
        </xs:sequence>
    </xs:complexType>
    <xs:complexType name="InterestType1Choice">
        <xs:choice>
            <xs:element name="Cd" type="InterestType1Code"/>
        </xs:choice>
    </xs:complexType>
    <xs:simpleType name="InterestType1Code">
            <xs:enumeration value="INDY"/>
            <xs:enumeration value="OVRN"/>
        </xs:restriction>
    </xs:simpleType>
    <xs:simpleType name="Max105Text">
            <xs:maxLength value="105"/>
        </xs:restriction>
    </xs:simpleType>
    <xs:simpleType name="Max140Text">
            <xs:maxLength value="140"/>
        </xs:restriction>
    </xs:simpleType>
    <xs:simpleType name="Max15NumericText">
            <xs:pattern value="[0-9]{1,15}"/>
        </xs:restriction>
    </xs:simpleType>
    <xs:simpleType name="Max15PlusSignedNumericText">
            <xs:pattern value="[\+]{0,1}[0-9]{1,15}"/>
        </xs:restriction>
    </xs:simpleType>
    <xs:simpleType name="Max16Text">
            <xs:maxLength value="16"/>
        </xs:restriction>
    </xs:simpleType>
    <xs:simpleType name="Max2048Text">
            <xs:maxLength value="2048"/>
        </xs:restriction>
    </xs:simpleType>
    <xs:simpleType name="Max34Text">
            <xs:maxLength value="34"/>
        </xs:restriction>
    </xs:simpleType>
    <xs:simpleType name="Max350Text">
            <xs:maxLength value="350"/>
        </xs:restriction>
    </xs:simpleType>
    <xs:simpleType name="Max35Text">
            <xs:maxLength value="35"/>
        </xs:restriction>
    </xs:simpleType>
    <xs:simpleType name="Max3NumericText">
            <xs:pattern value="[0-9]{1,3}"/>
        </xs:restriction>
    </xs:simpleType>
    <xs:simpleType name="Max4Text">
        </xs:restriction>
    </xs:simpleType>
    <xs:simpleType name="Max500Text">
            <xs:maxLength value="500"/>
        </xs:restriction>
    </xs:simpleType>
    <xs:simpleType name="Max5NumericText">
            <xs:pattern value="[0-9]{1,5}"/>
        </xs:restriction>
    </xs:simpleType>
    <xs:simpleType name="Max70Text">
            <xs:maxLength value="70"/>
        </xs:restriction>
    </xs:simpleType>
    <xs:complexType name="MessageIdentification2">
        <xs:sequence>
            <xs:element maxOccurs="1" minOccurs="0" name="MsgNmId" type="Max35Text"/>
        </xs:sequence>
    </xs:complexType>
    <xs:simpleType name="Min2Max3NumericText">
Previous Topic:Weaving EclipseLink entites
Next Topic:secure password and user name in persistence.xml
Current Time: Sun Nov 09 02:55:50 EST 2025
Powered by FUDForum. Page generated in 0.04727 seconds
